1995 civic code 43 help.
h22 POWA
fixed, was o2 sensor
Re: 1995 civic code 43 help.
So code 43 is....?
injectors?
http://wiki.answers.com/Q/92_honda_c...ou_need_to_fix
It can actually be multiple things on a Honda. Typically, it will be your primary O2 sensor, your fuel filter being clogged, or the fuel pump not supplying enough fuel to get the job done. Also, contrary to what another answer had said, the O2 sensors are NOT in series. The front (primary) O2 is used to fine tune adjustments and the rear (secondary) O2 is used simply to verify the catalytic converter is doing its job.
h22 POWA
sorry i didn't post but yes it means fuel supply system, but i fixed it, it was my o2 failing on me. car fixed now
