1995 Chevy Impala: easiest way to remove motor? HELP!
fuck this shit
Well, I know how to remove motors, I have a hoist/cherry picker, jackstands and many tools/wrenches/sockets etc, but I need a little help on how exactly to remove the motor. I'm assuming it's just a matter of pullin off all accessories, but what else do i need to do to make this go the quickest?
Thanks in advance!
Thanks in advance!
Re: 1995 Chevy Impala: easiest way to remove motor? HELP!
you can, just make sure everything is disconnected from the tranny, like linkages and lines etc etc, and remove the crossmember, should come right out
NAZI mod
Drain all the fluid. You don't even have to remove accessories.
Remove hood
unbolt and remove driveshaft
drain fluids
dissconnect shift linkage
dissconnect all electrical plugs from wiring harness
remove ac lines
dissconnect fuel lines
dissconnect tranny cooler lines
unbolt crossmember
unbolt motor mounts
pull motor
Remove hood
drain fluids
remove ac lines
unbolt crossmember
unbolt motor mounts
pull motor
