1995 Accord Problem
Old 11-21-2011, 03:03 PM
slowd16y8's Avatar
slowd16y8 has disabled reputation
Default 1995 Accord Problem
I have a 95 accord ex 4 door with a 97 f22b1 that was swapped before I bought the car. Its been running fine until today on my way home. My Speedo and Tach both stopped working and the ABS light came on. The Vtech stopped functioning and when I pulled in the driveway and turned it off I tried to restart it figured it would reset the abs light and it wouldn't crank back up. I get juice to the car so I know the battery is good, could the alternator be the issue or am I looking at something bigger? Any help would be greatly apprieciated.
slowd16y8 is offline
Old 11-21-2011, 03:42 PM
aacjohnc's Avatar
Sound like Ecu went into limp mode.dont think its your alternator but test with volt meter.should be round 13 v to 14 but not below 12. If it is then you should know what to do next.i would try resetting ecu then go from there. Check all grounds to since its a swapp Honda
aacjohnc is offline
Old 11-24-2011, 08:57 PM
gameoverr96's Avatar
gameoverr96 has disabled reputation
Default Re: 1995 Accord Problem
i think your issue may be your crank position sensor.. if it cant read engine speed the ecu doesnt know what the rpms are also it will cause a crank but no start condition
gameoverr96 is offline
Old 12-04-2011, 10:06 PM
00_civic757's Avatar
00_civic757 has disabled reputation
Well the tachometer runs off the dizzy and the speed is determined by the vss on the tranny and without them working properly vtec wont work....take a look at ur engine harness and see if it has been hacked up at all since it's a swapped Honda
00_civic757 is offline
Old 12-05-2011, 01:13 PM
It sounds like a power or ground problem that is affecting multiple circuits like the ABS, the sensor power supply for the distributor, and likely the small starter relay also.
You could probably find a common link that relates those circuits to each other if you look at the schematics in the factory manual. Sooo probably a blown fuse or fusible link. The real question is what caused it to happen? You shouldn't be blowing fuses with a properly functioning electrical system. It might be something simple like a loose power, loose ground, corroded connection, etc.
WoRKedIT
01-10-2008 10:38 AM
ClutchCivEK07
03-23-2007 07:46 AM
Quick Reply: 1995 Accord Problem
