1992 GS-R Integra HELP!! Please
Old 07-22-2011, 11:43 AM
2up2down's Avatar
2up2down has disabled reputation
Default 1992 GS-R Integra HELP!! Please
I have a 1992 integra gsr shell and I bought a 1991 integra with an ls to swap into the gsr. I already pulled the motor now I have the problem of the ls harness not being able to fit into the already existing gsr harness in the shell and the ls ecu wont fit into the ecu port. Please help I need to figure this out. I know you can make a harness I am just looking for how to do so or any easier method!
2up2down is offline
Old 07-22-2011, 11:56 AM
Digital Life
83Stang5.0's Avatar
Default Re: 1992 GS-R Integra HELP!! Please
90-91 integra is obd0
92-93 are obd1
83Stang5.0 is offline
Old 07-22-2011, 12:02 PM
2up2down's Avatar
Whats my best option? quickest amd cleanest haha
2up2down is offline
Old 07-22-2011, 12:19 PM
Get an OBD1 LS harness and ECU. They're both cheap and plentiful. You could have got an entire OBD1 LS engine for a few hundred bucks.
Old 07-22-2011, 12:20 PM
Whatever it takes
ls/vtecstitch's Avatar
ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch ls/vtecstitch
you need to sell your obd 0 ecu and pick up an obd 1 ecu or get a jumper harness. then you are going to run into distributor and injector issues but all of this is very easy to take care of. the ecu in my opinion would be my first priority. Just my .02
edit: beat me to it. ^^^^^^^
ls/vtecstitch is offline
Old 07-22-2011, 12:48 PM
2up2down's Avatar
Thank you so much guys for your help! So the existing harness in the gsr will be compatable once I get another engine harness for the ls engine?
2up2down is offline
Old 07-22-2011, 04:57 PM
Yes, the OBD1 B-series harnesses are compatible, and the LS harness usually doesn't have the VTEC and knock sensor wires that the GSR has. The LS is a B18B remember, so pretty much everything external to the engine is compatible with the external parts of other B-series engines.
It is true though that you may need some miscellaneous things like OBD1 injectors. Oh, and if the LS engine you have is a cable actuated clutch, you might want to get a different transmission that is a hydraulic actuated clutch to match the GSR shell. This is why I was saying it's sometimes easier to buy a OBD1 LS engine/trans which will drop right into the GSR.
Old 07-22-2011, 06:26 PM
2up2down's Avatar
I figured it out! I need a obd1 distributor a 92-93 harness and a ecu and I am good!
2up2down is offline
Old 07-22-2011, 06:29 PM
Yep, that should do it. And some injectors, unless you want to use a resistor box.
Old 07-23-2011, 09:10 AM
Whatever it takes
dpn't forget this is a DA gs-r so the tranny that was in it originally was a cable one. He should not have to worry about the tranny not being compatible.
Quick Reply: 1992 GS-R Integra HELP!! Please
