1969 GTO - Need traction! Help!
Old 07-31-2003, 09:27 PM
Desolate_Flux's Avatar
Desolate_Flux is an unknown quantity at this point
Default 1969 GTO - Need traction! Help!
Alright, heres how it goes. I've got a 69 GTO, I need traction. I'd like for the wheels to not be ONLY useful in the dry weather, and at least work somewhat in the imperfect weather.
I want it to look muscle, look hot, but be 100% legal. I need traction badly. Hell, I start off in second gear, trying to get a racing launch, and do nothing but spin... I shift from third to fourth on the highway, and get WAY too much spinning (can we say - UNSAFE?)
What are my options, and what are my most COST EFFECTIVE options? Trying not to spend thousands here...
Desolate_Flux is offline
Old 07-31-2003, 10:38 PM
-8th Day Clothing-
Broke Neck's Avatar
Broke Neck Broke Neck Broke Neck Broke Neck Broke Neck Broke Neck Broke Neck Broke Neck Broke Neck Broke Neck Broke Neck
26/11.5/15's
Mickey Thompson E/T Streets $163 X 2 = $326
Broke Neck is offline
Old 07-31-2003, 10:43 PM
-8th Day Clothing-
Broke Neck's Avatar
OOPS ... sorry didnt see the thing about not just for dry weather.
Old 08-01-2003, 02:13 AM
Nic
Nic's Avatar
Nic Nic Nic Nic Nic Nic Nic Nic Nic Nic Nic
how about some lift bars and drag radials?
Nic is offline
Old 08-01-2003, 03:01 AM
nickyroo's Avatar
Nitto 315/x/x drag radials & a posi will help.
what gear are you running? maybe youve got a little too much gear in it for not having slicks?
nickyroo is offline
Old 08-01-2003, 07:45 AM
Iridium V
MGBRaceman's Avatar
MGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond repute
1: Fender flares
2: Wide Tyres (sticky too) Potenza SO-3 Pole Position
3: Traction Bars
4: Stiffer Suspension including bushings
5: Limited Slip Rear End
6: Polyurethane transmission and motor mounts
MGBRaceman is offline
Old 08-01-2003, 06:34 PM
Former 757'er
Blasphemous's Avatar
Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous Blasphemous
What kind of suspension do you have in the rear?
Try some drag shocks, about a 50/50 or 40/60.
Put on some traction bars or ladder bars.
Run some BFG drag radials.
Also, is it AT or MT? What ratio of gears do you have?
Blasphemous is offline
Old 08-01-2003, 09:35 PM
nickyroo's Avatar
Blasphemous hows the Olds comin along? man i came across a friend of mine's uncle's cutlass with a big block in it the other day. its sitting in his backyard rusting itself to death. makes me sad.
nickyroo is offline
Old 08-02-2003, 04:38 AM
Former 757'er
Well, I unfucked the wiring to the altenator. So, it's working right and not killing batteries now. The motor's just killing starters, so I got a Power Master high torque mini-starter. That's going in today. I've also re-ran the lines for the air suspension so that each shock has it's own line and mounted them in the trunk. I'm not worried about putting in real shocks because I can get a full 4-link setup for about $250.
What year is that Cutlass and if it's a 71-72, would he sell it?
the goat
Domestic
21
10-05-2008 09:41 AM
nftuatn
Import - EUROPE
12-29-2007 04:53 PM
Quick Reply: 1969 GTO - Need traction! Help!
