01 gsr radiator fan problem
Old 05-18-2015, 03:52 PM
alnagrom88's Avatar
alnagrom88 has disabled reputation
Default 01 gsr radiator fan problem
Not sure why my radiator fan isnt coming on when vehicle is warmed up or driving at all what could cause this?
alnagrom88 is offline
Old 05-18-2015, 05:49 PM
ej1995's Avatar
ej1995 ej1995 ej1995 ej1995 ej1995 ej1995 ej1995 ej1995 ej1995 ej1995 ej1995
Default Re: 01 gsr radiator fan problem
The temperature switch, the relay, the motor itsself has gone bad.
Did you do ANY research? Did you check for voltage at the fan and work your way back? What happens when you turn on the A/C?
ej1995 is offline
Old 05-18-2015, 06:18 PM
Mirrorimg's Avatar
Mirrorimg is a name known to allMirrorimg is a name known to allMirrorimg is a name known to allMirrorimg is a name known to allMirrorimg is a name known to allMirrorimg is a name known to all
first thing you should look at are the fuses.
Turn on the AC like ej1995 said, they both should turn on.
google images returned this 2001 diagram for the engine fuse box. You need to check the condenser and cooling fan fuses if one of the fans doesnt turn on with the AC on.
Mirrorimg is offline
Old 05-18-2015, 07:38 PM
VaDriven Mayhem
Lord Humongous's Avatar
It's probably the Steering wheel- seat interface
Lord Humongous is offline
Old 05-18-2015, 07:39 PM
Check the fan temp switch first. They like to go bad on Hondas.
Old 05-19-2015, 12:52 AM
alnagrom88's Avatar
Ac doesnt work i think my system needs to be charged up no compressor kicks on i haven't checked voltage dont have a volt meter i did read how to jump the fan out.
Old 05-19-2015, 04:28 AM
Buy a voltmeter or you have no way of diagnosing this. The only thing you'll be able to do is blindly replace parts.
Old 05-19-2015, 01:50 PM
alnagrom88's Avatar
I will thanks!
Old 05-20-2015, 06:26 PM
ej1995's Avatar
Tell me why it matters whether the compressor kicks in or not? If you can't answer that question(which I'm guessing that you can't), you should maybe find yourself a reputable repair facility...
ej1995 is offline
Old 05-21-2015, 08:25 AM
CRXB5's Avatar
CRXB5 has disabled reputation
you can always run your own basic power and ground wiring to the fan and hookup a toggle switch and mount it into the dash,
heres a good/helpful link for diagnosis though
http://honda-tech.com/honda-accord-1...ystem-2793650/
CRXB5 is offline
C_WAKE
Engine / Exhaust / Drivetrain
12
12-01-2010 02:48 PM
Boriqueño
06-10-2009 07:39 PM
Quick Reply: 01 gsr radiator fan problem
