01 gsr radiator fan problem
Not sure why my radiator fan isnt coming on when vehicle is warmed up or driving at all what could cause this?
Re: 01 gsr radiator fan problem
The temperature switch, the relay, the motor itsself has gone bad.
Did you do ANY research? Did you check for voltage at the fan and work your way back? What happens when you turn on the A/C? |
first thing you should look at are the fuses.
Turn on the AC like ej1995 said, they both should turn on. google images returned this 2001 diagram for the engine fuse box. You need to check the condenser and cooling fan fuses if one of the fans doesnt turn on with the AC on. http://acura.my3gb.com/images/00-acu...diagram-10.jpg |
It's probably the Steering wheel- seat interface
Check the fan temp switch first. They like to go bad on Hondas.
Ac doesnt work i think my system needs to be charged up no compressor kicks on i haven't checked voltage dont have a volt meter i did read how to jump the fan out.
Originally Posted by ej1995
(Post 8354387)
Buy a voltmeter or you have no way of diagnosing this. The only thing you'll be able to do is blindly replace parts.
I will thanks!
Originally Posted by Fabrik8
(Post 8354415)
Originally Posted by alnagrom88
(Post 8354406)
you can always run your own basic power and ground wiring to the fan and hookup a toggle switch and mount it into the dash,
heres a good/helpful link for diagnosis though http://honda-tech.com/honda-accord-1...ystem-2793650/ |
