****auto to manual swap help*****
Old 11-02-2007, 07:19 PM
D15b1>k20a
kf91da9's Avatar
kf91da9 has disabled reputation
Default ****auto to manual swap help*****
ok im swappin a da from auto to manual..got the tranny in.. but just need a clutch cable is there anything else electrical or any other issues that i might have.. let me know..thanks for ur help
kf91da9 is offline
Old 11-02-2007, 07:31 PM
1rude2l's Avatar
Default Re: ****auto to manual swap help*****
have to tie a couple of the wires together at the auto shifter plug, two big wires if i remember correctly. Have to hardwire backup lights. Drill hole for clutch cable we used a wood boring bit.
1rude2l is offline
Old 11-03-2007, 08:18 AM
D15b1>k20a
kf91da9's Avatar
tanks for tha help bro
kf91da9 is offline
Old 11-03-2007, 03:08 PM
1rude2l's Avatar
its a hard first timer job good luck!
1rude2l is offline
Old 11-03-2007, 03:55 PM
bmw-m's Avatar
bmw-m has disabled reputation
make sure when u splice the shifter wires together u dont do it on the harness side. cut the plug off the shifter so that u can always plug one back in(not that u would want to)
bmw-m is offline
Old 11-04-2007, 05:27 AM
vanhorn5378's Avatar
vanhorn5378 has disabled reputation
change ecu to keep light off drilling that hole is a pain in the ass drill a couple of holes after you mount the shifter use bolts and nuts and if memory serves me correct you will have to grind the mount to make it slide in the body good luck it only took a few hours when I did mine changing the pedals and everything
vanhorn5378 is offline
Old 11-04-2007, 08:32 AM
D15b1>k20a
kf91da9's Avatar
muchas grasias for the help
kf91da9 is offline
Old 11-09-2007, 11:01 AM
not a noob
JAvenger's Avatar
JAvenger has disabled reputation
http://hondaswap.com/swap-articles/a...version-27054/
JAvenger is offline
flacopower
Want to Buy / Trade ARCHIVE
02-17-2008 10:39 PM
02civicrider
02-05-2008 03:44 PM
Spike101
03-02-2006 04:49 PM
Mkiii_Jetta
07-08-2005 07:00 PM
LDxShyGuy
01-07-2004 09:40 PM
Quick Reply: ****auto to manual swap help*****
