$20.00 .... crank pulley help
if you can get it off of my stock 91 crx ill give you $20. im located in newport news in the menchville area.
Re: $20.00 .... crank pulley help
soak the bolt in pb blaster, put it in gear, have someone mash on the brakes and use a huge cheater pipe. it'll come off.
doesnt run due to ripped timing belt
dont have a breaker bar
i got a breaker bar u can borrow i stay in nn near the intersection of main and jeff.
hollow tubing over the handle of your ratchet works as a breaker bar...
no shit
better way to do it. put a breaker bar in the end, take the car out of gear and try to start it. it will break it loose in a heart beat. i have done it many times.
The easiet way to get it off would be go buy an air compressor and impact and she'll definatly come off!! |
