Viper alarm with remote start Model: 5701
Hey all I have a brand new Viper alarm Model: 5701 with remote start for sale....
I also have both wiring and bypass harnesses to make the job easier! XK07 and XK02..
XK02:
http://www.bypasskit.com/product.aspx?prodid=XK02
XK07:
XK07 is a programmable High Speed CAN Controller platform designed to interface with vehicles equipped with a High Speed Controller Area Network.
VIPER ALARM/REMOTE START Model: 5701
FEATURES:
* Silent Mode2: "Paging-only" allows users to turn off the siren and receive notifications on the remote only. The vehicle "silently" alerts the user that the alarm has triggered.
* Longer Battery Life: 3 to 6 months.
* Microprocessor function control, powered by an 8 MHz microprocessor running SuperCode software-based encryption: a smarter and safer, more robust coding scheme which supports more functions on more cars
* Real Status: Temperature check and run time check using GhostLights
* On-board remote adjustable shock sensor on hybrid models
* Onboard Flex Relay and Flex Light Flash Relay
* Virtual Tach: Advanced tachless solution
* Combined Status LED and Valet Switch: Now mounted in the antenna housing for easy access and quicker installation
* Manual Transmission Remote Start: Built-in, enabling RS installation on the millions of stick shift vehicles on the road.
* Veri-Temp: Smart cab temperature check.
* Universal Data Interface slot for XKAll / XpressKey making Responder LE our first data enabled 2-way product.
* Real Time Status (including temperature, run time remaining, battery life).
* No-Start/shut down diagnostics through parking lights.
* Improved comfort Closure for higher European and Japanese vehicle compatibility.
* Remote Controlled Rear Defrost Output
* On-Board Thermistor: temperature controlled timer/start mode: SmartStart
I will let it go for $350 plus shipping......
You can contact me here or at [email]GSXR692003@yahoo.com
XK02:
XK07:
FEATURES:
Re: Viper alarm with remote start Model: 5701
very interested! do you still have it?
Fl1pSde 101
10-30-2008 09:54 AM
