TURBO KIT!
TURBO KIT!
I have a 100% complete IAP Stage 1 turbo kit with a bunch of extra's I am thinking about selling. It has about 8k miles on this kit sans the manifold which has about 650 miles on it.
Details on the turbo kit can be found here:
Import-Autoperformance.com - The Anti-Swap! 240SX Stage 1 Turbo Kit 210+HP
Retail on the kit is 3800$ but the shop is running a special for $3000 right now.
Specs below:
50 trim T3/T4 IAP/Garrett turbo-360 degree thrust bearings,dual journal bearings, Garrett GT series wheels and outstanding quality.(THERE IS -0- SHAFT PLAY ON THIS TURBO)
Walbro High Pressure/High Volume 255 LPH Fuel Pump (recommended) or Vortec FMU (connections not included due to user placement of FMU). Either of these units provide the extra fuel needed for those with an aftermarket boost controller who plan on exceeding the stock Stage I kit's 7 PSI of boost. (I have both so you can pick which you want, both used)
Oil Feed/Return Lines-Stainless steel braided line, with custom fittings and PRE TAPPED KA OIL PAN.
Front Mount Intercooler-Blackstone core,custom made to fit in the factory bumper area. Overall measures 27" wide X 6" tall X 2.5" deep. Our intercoolers are tested to 40PSI under water to ensure leak free performance and support up to 550HP.
2" Intercooler piping/silicone couplers/hose clamps. Intercooler piping is shipped with Greddy Type RS or Vortech (your choice) BOV
Tial 38mm Wastegate.
IAP Custom Equal Length Turbo Manifold and Downpipe. (IAP Downpipe mates up to SR20 downpipes).
Also included is a Megan Racing Stainless Steel SR20 downpipe with flex pipe.
Looking for around 2600$ O.B.O. for the turbo kit.
I also have a fuel management setup designed for this very turbo kit. I will included for under fair market resale value if you buy the kit at my asking price. At this time I will NOT sell the items below until the kit has sold.
-Enthalpy ECU tuned for exact setup
-Z32 MAF Sensor
-Deatschwerks 555 injectors
And a few other supporting mods:
-3" Megan resonated test pipe
-3" Megan Exhaust S14
-Spec Stage 4 clutch
-Fidanza 11lb Flywheel
Make me a reasonable offer and you can have the entire setup for a very reasonable price! The kit is still currently on my car and running great. I will be removing the kit within the week.
Specs below:
-Z32 MAF Sensor
Re: TURBO KIT!
good turbo GLWS!
Re: TURBO KIT!
Re: TURBO KIT!
Re: TURBO KIT!
Re: TURBO KIT!
Re: TURBO KIT!
Re: TURBO KIT!
Re: TURBO KIT!
Re: TURBO KIT!
