testing waters turbo b16 swap
i have a b16 swap that came out of a 00 si that had 51xxx miles on it..
here is what it has:
inline pro t4 manifold
inline pro intercooler piping
inline pro 3 inch v band down pipe
inline pro feed and return lines
godspeed intercooler 27x11x3
44mm v band tial wastegate
50mm tial blowoff valve
precision 880 injectors
arp headstuds
3mm cometic headgasket
act stage 3 clutch and pressure plate
garrett 70 trim turbo
00 jdm type r cams
aem true time cam gears
gm 3 bar map sensor
stock honda axles
00 si shift linkages
avid extreme race mounts [all five]
this is everything i can think of right now im sure im missing something car made 308 hp on 12 pounds and ran 7.90 in 1/8 mile @ 92 mph on 225/50/15 bfg drag radial have video to prove could get dyno sheet if needed will take you for a ride in the car before i pull the swap if you have cash in hand motor is tuned on aem asking $5,500 without aem and $6,500 with aem
arp headstuds
00 jdm type r cams
gm 3 bar map sensor
stock honda axles
Re: testing waters turbo b16 swap
