Race Ready 383 LT1 Stroker!
This is a monster of an engine, with a lot of extras! It's an almost complete setup, with only a few minor parts and final assembly required, which should yield well over 400 WHP and 400 WTQ of torque in any Corvette, F-Body, or Caprice/Impala, or swap it in something else.
This sale includes:
383 Shortblock ~$5K build up
eagle 4340 forged crank
howard splayed caps 4bolt mains
ARP studs through out (heads had bolts not studs)
10:1 SRP pisted forged
file fit rings
eagle H-beam forged rods (6.0 in length)
clevite bearings through out
canton 7qt oil pan
high volume oil pump
Internally balanced, ~500 miles on it, will take a 300 shot of happy gas. Very clean! Ran less than a dozen runs on the strip with a 175 shot, and was pulling 9.9's!!!!
Three sets of LT1 heads
One set of stock F-Body LT1 heads,
One set of bare, but very very nicely ported and polished heads
One set of very nicely ported and polished heads with Isky racing three layer beehive springs
Optisparks!
Two brand new GM later style vented optisparks, still in the boxes.
Two Cams
Lingenfelter Performance 211/219 Cam
TPIS ZZ-409 Cam
Manifolds
2 spare LT1 manifolds, one bare, one red. Red one has some porting done to it.
McLeod ST!
Slightly used (3000ish miles) McLeod Street Twin clutch. The discs are in great shape. The flywheel could use a cleaning, but it's in great shape!! 1200 HP Holding strength means you won't burn it out anytime soon.
Misc Parts
58 MM TPIS Throttle Body
Built and matched 30 # injectors, within 1-2% of each other
NEW lifters
NEW Comp Cams Pushrods
You also get an extra engine! It's a good core for another buildup! From a 95 Trans Am with a spun bearing. All internals included, and they are mostly still good.
Price is set at $6000, which is a steal considering you'd spend well over $9000 if you add up all the parts and labor. If you think it's too much, email me an offer, and I'll consider it. I can also work with you for delivery!
This sale includes:
file fit rings
canton 7qt oil pan
Optisparks!
Two Cams
TPIS ZZ-409 Cam
Manifolds
McLeod ST!
Misc Parts
NEW lifters
ZO6Driver
03-01-2008 10:40 AM
