Great H2B SWAP---------TESTING WATERS
well its almost spring so it's time for people to start figuring out their car stuff for the year.
I have an H2B swap to offer that would make a very awesome street engine, or a really great track performer as well. here we go: im thinking on asking something around 5400$ BRAND NEW EVOLUTION H to B adapter plate kit Transmission Adapter Plate with Dowels One Piece Flywheel Polished Billet Motor Mounts with A70 Urethane Inserts CNC Machined Drivers Side Engine Mount Extended Shift Fork Clutch Slave Cylinder Adapter Intermediate Shaft Adapter All Necessary Hardware Complete Instructions Template for Block Notching PCV Adapter, to Clear Hood Better -Socketed and setup for data logging P28 ECU(has notch in ecu cover for fast chip changes as well as a speed socket) -Stock 4 wire O2 sensor -(4) ACCEL 36 lb/hr injectors (380 cc/min) New in box. High Impedance injectors. -ITR tranny w/LSD of course. Most trannys dont come with half the things i have listed. -mileage is roughly 50,000 -the tranny is in good working condition -bseries shift linkage -axles (boots are ripped, so theyll need replacing-cost 10$) -starter -upper tranny mount -flywheel cover -all hardware -A complete ready-to-go transmission. -(1997' head code) H22A1 longblock Most longblocks dont come with half of the hardware/mounts miscelaneous items i have, which is all taken into account in my price -Rocket motorsports valvesprings/retainers (new in box, worth $300) -Handmade tig welded $550 custom prototype H22 4-2-1 header with 2.5" collector, made for mild to medium cams -DC sports 4-2-1 ceramic coated header in really good condition, worth $150 -brand new phenolic thermal intake gasket, worth $50 -no intake manifold -engine wiring harness -H22 starter -H22 alternator -H22 distributor and wires with good cap and rotor -all engine/tranny mounts -intake manifold bracket, bolts, accesories, and sensors -halfshaft -timing belt plastic covers -everything between the valve cover and oil pan -engine has about 80,000 miles on it and was pulled from a well running car. -engine has not been taken apart. -BRAND NEW H22 JDM-type S OVERSIZED pistons/rings/pins, in the Honda boxes. only removed from box to look. |
Re: Great H2B SWAP---------TESTING WATERS
price?
