Fully Built d16 w/ turbo setup
I drive a coupe
Contact: (757) 343-1278
Price: Negociable
I am selling/trading my whole setup No low ball offers.
I am looking for COMPLETE K Series swap or cash. Make me an offer.
I have..
Bottom end $1200.00 OBO
D16z6
Bored .5mm and decked by Barnettes Machine Shop
Golden Eagle Block Guard
Wiseco 75.5mm Pistons
Eagle Rods
Balanced rotating assembly
Cleavite bearings
Ported oil pump
Prothane Solid Engine Mount Inserts
Head $1500.00 OBO
D16z6
Crower Titanium Springs and Retainers
Crower Stage 2 Turbo Cam
Skunk 2 cam gear
Ferrea 1mm oversized Pro-Flow Valves
5 Angle Valve Job
Ported and Polished by Barnettes Machine Shop
Cometic Head Gasket
ARP Studs
MSD 6AL ignition
Blaster 2 Coil
MSD Cap
Edelbrock VictorX Intake Manifold
Hondata Intake Manifold Gasket
Precision 1000cc Injectors
BBK 62mm Throttle Body
AEM Fuel Rail w/ Gauge and Adjustable Regulator
Transmission $1000.00 OBO
Competition Stage 4 Clutch w/ Heavy Duty Pressure Plate
Resurfaced Stock Flywheel
4.94:1 Final Drive Ratio
Carbon Synchronizers
Fresh Seals w/ New bearings
New Axles, still under Warranty from Advance Auto..
Electronics
GM 3 bar MAP sensor
Greddy Profec B spec 2 Electronic Boost Controller
Greddy Turbo Timer
p28 ECU tuned on CROME
Turbo Setup $1200.00
Precision SC3431e .60/.63 turbo (rated at 550 horsepower)
2.5" Charge Piping (only half is welded, other half has conventional couplers)
FMIC
HKS SSQV Blowoff Valve
Turbosmart Ultra-Gate Hi Temp 38mm Wastegate
3" Mandrel Bent Downpipe w/ 3 Bolt Flange to Connect with 3" Exhaust
Price: Negociable
I have..
D16z6
Eagle Rods
Cleavite bearings
Ported oil pump
Head $1500.00 OBO
D16z6
Skunk 2 cam gear
5 Angle Valve Job
Cometic Head Gasket
ARP Studs
MSD 6AL ignition
Blaster 2 Coil
MSD Cap
Electronics
GM 3 bar MAP sensor
Greddy Turbo Timer
FMIC
Slammedxpert
Re: Fully Built d16 w/ turbo setup
Last time I saw this setup, shit was ridiculous! (It's Mike BTW)
Good, raw power single cam!
Gettin it!!!
How many miles are on this setup? Any numbers?
I drive a coupe
I don't have numbers.
The motor currently has less than 20 miles on it.
I drive a coupe
pictures bump
I drive a coupe
Nice build.
sh!ttyLS
10-03-2008 08:25 PM
gotboosthatch
10-06-2007 09:16 PM
