FS: MANY ENGINES, GM, Ford, Honda, Toyota, Mitsubishi, MORE! LOOK! CHEAP!!!
Body In Trunk.
I have stockpiled a buncha powertrain stuff over the past couple years, they needa GO! I have everything from a little mitsubishi 4 cylinder here to an 8.2l (500ci) cadillac V8 so look em all over and let me know if any of it interests you!
I also have a buncha transmissions, vehicles and other shit, feel free to look up my other threads and chek em out!
-All prices are OBO
-this stuff is located in Richmond VA
-I can be reached at 804 986 3152
-or on AIM: RCR Roscoe
-and e-mail: roscoe@automotivelifestyle.com
First up is an engine from an acura integra ls, 120 k, this can be started up so you can hear it run if you wish! the rest of this vehicle is also available in another thread, look it up! trying to sell the complete swap (EVERYTHING) for $1000 obo. (you remove) add $150 if we remove it for you. SOLD!
Next we have a 3.0 24 valve v6 pulled from a 96 toyota avalon, same as one in many toyota / lexus vehicles! car had apprix 130 k and ran great, car kinda went airborn! the trans and everything you see dangling there is included! $500 for it all!
this one is a 500 cubic inch v8 i pulled from a 1975 sedan deville, car ran and drove great! mileage is unknown, could be 50 k, could be 150 k, your guess is as good as mine. it comes with the transmission witch is a BOP pattern th400 long shaft. ill also included the driveshaft. $600 OBO
this mitsubishi engine was removed from a chrysler minivan with about 130k on it, this is the mitsu "g54b" witch is more or less the same one as in some of the trucks and the starions / conquest. this i am told has the non jet valve head on it! $300 OBO
-All prices are OBO
Body In Trunk.
Re: FS: MANY ENGINES, GM, Ford, Honda, Toyota, Mitsubishi, MORE! LOOK! CHEAP!!!
need a diesel? this oldsmobile based 350 diesel was in a buick rivera, this is a factory replacement engine with all the problem areas "fixed" car ran strong when this was removed, the fwd transmission is also included. mileage is unknown but i assume is fairly low.
anyone up for a sweet swap? 4.6l 32 valve V8 pulled from a lincoln MK8, this is more or less the same engine found in the earlier cobras with the quad cam motor. main differences are the intake manifold and ofcourse the programming. the ecu, engine harness and trans are included with this swap. i do not have the trans harness tho. $1000 OBO!
while i am on fords, i have a healthy 460 big block in a 70's ford f-100 pickup. it needs carb help (power valve??) but runs pretty good, no bad sounds whatsoever. not sure what trans is behind this but its yours free with the motor if you want it. $400 you remove, add $100 if we pull it for you.
Body In Trunk.
last but not least is an odd bird, this is an over head cam inline 6 that was pulled from a 67 tempest. its locked up but im told it was fine when parked sometime in the 80's. good core for a unique project? trans is included.. $400 obo
THANKS FOR LOOKING! I will try and keep this thread updated
Body In Trunk.
bump, make an offer!
Body In Trunk.
$200 sale is over. boo!!
civiccord
Offroad / 4x4 ARCHIVE
08-08-2007 11:50 AM
