FS: Built 2.0 Gsr Swap
Engine:
1995 B18C1 w/ 98 Gsr tranny(built by BBJ) Bottom End: 84mm Darton M.I.D Sleeves (done at abacus racing) 84mm Endyn Forged Pistons 9.5:1 Eagle Rods Integra Type R Water Pump Integra Type R Oil Pump Integra Gsr transmission 6 Puck Clutch ACL Rod bearings Head: ARP headstuds Skunk2 Type R Intake manifold Portflow Dual Valvesprings Portflow Titanium Retainers Supertech Valves Cometic 84mm Head Gasket Integra Type R Vtec solenoid 00 Honda Civic Si Distributor 00 Honda Civic Si Wiring harness w/ Obd-O injector clips and resistor box Precision 780cc injectors (will include rc 550cc injectors) Msd 6A ignition Poly-urethane Motor Mount Inserts STR Fuel Rail 8mm Ngk Spark Plug Wires Aeromotive Fuel Pressure Regulator Fuel Pressure Gauge swap has less than 2k miles on it.. has never been really opened up.. its a good strong motor that can also be used for a good all motor set up.. all you really need to do is change the pistons to high compression pistons.. asking price is $4200 obo.. |
Re: FS: Built 2.0 Gsr Swap
TTT
BUY ME
TTT
TTT
TTT
TTT
no one likes to go fast anymore?
UP UP UP
TTT
