electronic boost controller
i have a pretty good boost controller for sale. for only $250 obo brand new 706-631-9844 give me some offers im not firm
Electronic boost controller + turbo timer + nitrous
BCU+ 4TH GEN
Brand new 4th generation design - more than just a standalone electronic boost controller. It does these functions:
TURBO TIMER
BOOST CONTROLLER
TWO PROGRAMMABLE OUTPUTS
It has these features:
PRESSURE DISPLAY IN PSI
PROGRAMMABLE TURBO TIMER (CAN BE USED WITH DUAL OR SINGLE IGNITION)
PARKING BRAKE TURBO TIMER OVER RIDE
2 PROGRAMMABLE CHANNELS THAT CAN CONTROL
POSITIVE OR NEGATIVE CONTROL
NITROUS SOLENOID
INTERCOOLER SPRAYER SOLENOID
DEDICATED HI AND LO BOOST SETTINGS
PROGRAMMABLE WARNING SETTINGS (BEEP AND DISPLAY FLASH)
PROGRAMMABLE HI & LO GAIN
START BOOST CONTROL FOR QUICKEST SPOOLING
PROGRAMMABLE LIMIT SETTING TO PREVENT OVERBOOST
PEAK BOOST RECORDING AND LAST BOOST HOLD DISPLAY
TURBO TIMER CAN BE USED MANUALLY OR AUTOMATICALLY - SELF SETTING BASED ON BOOST & DURATION
VOLT METER DISPLAY
SOUNDS CAN BE TURNED ON AND OFF
DISPLAY IN 6 SETTABLE COLORS TO MATCH YOUR OEM GAUGES.
PROGRAMMABLE BASELINE PRESSURE (FOR USE AT HIGH ELEVATIONS)
Works with single or twin turbos, and runs internal or external wastegates up to 25.5PSI. This has a high quality internal pressure sensor, and a high quality fast response boost control solenoid.
This boost controller builds in the features of several items at once (turbo timer, boost controlled solenoid outputs, etc). It's fully programmable. It can be top or bottom side mounted and includes the mounting bracket and hardware as well as all harnessing. A full manual is included with all wiring diagrams, programming instructions and plumbing instructions for the wastegate and pressure sourcing.
BCU+ 4TH GEN
TURBO TIMER
BOOST CONTROLLER
NITROUS SOLENOID
VOLT METER DISPLAY
