CHEAP 240SX PARTS, NEED TO GET RID OF, WATER PUMP, INTAKE MANIFOLD ECT.
UPDATE, CHEAP 240SX PARTS, NEED TO GET RID OF, INTAKE MANIFOLD, P/S PUMP, ECT...
contact: 8047392601 not after 9 though, This thread, or p.m.
Disc: these parts came off 2 different 240sx's, they are known to be in good working order, will not take trades, may if possible, if youre interested get ahold of me and we'll work it out. more pics available on request, prices are negotiable
Parts:
upper and lower intake manifold off of single cam ka24e, comes with fuel rail and injectors, wiring has been removed, upper and lower has been seperated, not sure on the location of the bolts -$25-
turn signal and wiperblade switch -$10-
distributor with wires off ka24e -$15-
fan clutch off ka24de -$10-
waterpump and pulley, off a ka24de, the water pump had been replaced no more than 2 weeks before it was removed its been in a sealed bag since removal -$15-
ecu out of 92 with ka24de -$25-
uncut engine side of wiring harness, goes from ecu to all the motor elec. connections, stops before trans, includes mafs connection, just doesnt go to head light ect -$25-
2 spare tires for 92 4 lug -$10 for the pair-
single cam valve cover painted red -$10-
single cam and dual cam oil pans -$10 each-
single cam p/s pump -$10-
rack n pinion from 92 dual cam w/o tie rods -$15-
front engine cover off dual cam (clean) -$10-
steering colum off 91 single cam needs ign. switch -$10-
crank pulley 92 dual cam -$5-
Parts:
Re: CHEAP 240SX PARTS, NEED TO GET RID OF, WATER PUMP, INTAKE MANIFOLD ECT.
some parts gone update
please buy this stuff
got a maf and plugs .. sohc
do you still have the ecu?
TACKLEBERRY
09-24-2008 03:08 AM
