B AND D SERIES SELL OUT BUILT GSR
SO TIMES HAVE GOTTEN RUFF HAVE TO SELL MY BUILDS AND OTHER PARTS SO ON WITH THE LIST
FRESH GSR SHORT BLOCK BUILT 0 MILES ON BUILD NEW CTR PISTONS TEFLON COATED ON GSR RODS BORED 82MM TYPE R OIL PUMP NEW WATER PUMP NEW MAIN AND REAR SEALS ALL NEW GASKETS NEW ACL RACE BEARINGS ROD AND MAIN NEW RINGS CAN THROW IN A NEW HEAD GASKET $800 COMPLEATE GSR HEAD WITH SKUNK 2 VALVETRAIN FLAT FACE VALVES DUAL VALVESPRINGS AND RETAINERS STOCK GSR CAMS SKUNK 2 CAM GEARS COMPLEATE HEAD WITH VALVE COVER AND DIZZY $400 COMPLEATE AEBS MANIFOLD FOR GSR COMES WITH ALL SENSORS THROTTLE BODY FUEL RAIL B &M FUEL PRESURE REGULATOR HAVE A NEW GASKET ILL THROW IN $150 B16 CABLE TRANNY NO GRINDS OR POP OUTS $200 GSR LIGHTEN CRANK PULLY NEW NEVER USED $30 OBD0 VTEC SUB HARNESS $50 OBD0 B16 PR3 CHIPPED ECU 3800 VTEC $100 EF 88-91 CIVIC CRX B SERIES MOUNTS NEW $120 CTR PISTONS TEFLON COATED NEW $200 D SERIES EXEDY STAGE 2 CLUTCH AND PRESURE PLATE $100 IF INTERESTED IN ANY PARTS YOU CAN CALL ME 804-837-2620 AFTER 9PM OR 804-347-1704 WAYNE |
Re: B AND D SERIES SELL OUT BUILT GSR
morning bump need money
is the d series cluth for cable?
