01-03cf,egshell,zex,efparts,dcparts,act,jdm,dc,turbo
Parts House
need to clear out some old stock...
Ill Try to list them in order of the pics on photobucket album.
92-95 eg or 94-2000 integra drivers side bseries alumn. mounts $30 each
ls and gsr intermediate shafts $75 each
auto bseries int shafts $20 each
stge 2 or 3 act b-series axles (one needs boot replaced) $125 set
ef si cluster $50 each
ZEX kit 75 shot just pulled from car works perfect $250
jdm dc 94-00 integra cluster $75
94 eg hatch 5sp needs motor and title
light rf damage needs fender headlight and hood. $600 as is without title.
94 eg hatch shell rolling chassis needs front end panels and lights most of the interior is intact title in hand ready to go $600
95 integra 4dr parts for sale anything on the car is up for grabs, still about 90% intact will sell whole for $800 title in hand
Dc rear disc conversion with prop valve,master cyl and e brake cables $250
2.25 drop spring unkown brand $25
DC 4-1 header kindof beat up but not leaking $60
LS long block good compression ,came from totaled 94 integra with 135k vc not included $ 300
ACT stge3 unsprung clutch disc and pressure plate (used)
$60
fresh pressure tested 95 ls cylinder head $100
turbo from dsm no shaft play $60
hf exhaust manifolds $40 each
94-00 integra rear disc setup with e brake cable $150 per set
EF si front hubs with cross drilled rotors and camber kit brand unknown
$125 for set
01-03 carbon fiber hood 2dr or 4dr (new in box) off brand
has hood squirter holes without rolled edges $250
here is the link to pics of listed parts http://smg.photobucket.com/albums/v637/92dx757/?start=0
Please CALL or pm with any questions
Thanks for looking
757-963-2213 Or 757-237-2939
$60
$125 for set
Thanks for looking
Parts House
Re: 01-03cf,egshell,zex,efparts,dcparts,act,jdm,dc,turbo
Parts House
do you still have the cluster do you think i can plug it into my ef and the rpm gauge work?
Parts House
not sure if it will work but you can test it before you buy
Parts House
Parts House
Parts House
blue hatch DOES NOT HAVE TITLE
Parts House
