Turbo/ DSM parts FS
Turbo/ DSM parts FS
First of all, I am in PA so I cannot meet up with you in Richmond to sell you an a/f ratio gauge. I can ship nearly everything, but larger items will need picked up.
Built longBlock:
-6- bolt
-Bored .20 over
-Ross Racing Pistons (8:3 to 1)
-Manley H-Beam Rods
-Acl main and rod bearings
-Balance shaft eliminator kit
-New oem oil pump
-New alternator
-New front and rear main seals
-New oem crank pulley
-New oem tensioner
-Greddy kevlar racing timing belt
-ARP Mains
-OEM Mitsubishi oil filters with Mobil 1 oil
-Full port job done by Norpa machine in Woodbridge, Va
-Complete valve job
-Manley 1mm oversized valves with valve springs and retainers
-New valve stem seals
-Cometic head gasket
-ARP headstuds
-Receipts for motor internals. I drove this setup for 5 hours straight back from VA where I bought the car and it drove perfect. Compression is perfect as well. This entire setup has a couple thousand miles on it, so everything is proven to have been built well!!
--I will sit on this for months if I get lowball offers unless I need space or something--
-1800
PTE sc6165s w/ feed/ drain lines, 2.5" silicone 90* coupler and homemade o2 housing--turbo has less than 1k miles and has ZERO shaft play! Truly a monster!!- 650
Sparco Milano adjustable race seats (very low use)--most comfortable aftermarket seat out there!!! These retail for over 1k each with sliders!!!!- 700 for the seats minus sliders, 800 with sliders
Extreme Psi Intake w/ filter and mas and couplers-75
FP Manifold tapped for EGT probe-175
2g Punishment Racing FMIC w/ fake greddy bov- 325
Punishment Racing SS 02 housing(Recirculated).- 100
Tripod with Prosport Gauges(Boost, Oil Pressure, Egt)- 125 for all 3 w/ triple pillar pod
2g awd Tein SS Coilovers (1k miles)- 700!! these have an incredible ride and look AWESOME on the car!!! You'll pay more than this for a strut/ coilover combo so scoop these up!!!
Greddy silver full auto TT- 70
2g awd fuel sending unit/ housing and all misc sensors-40
Hallman Pro RX Boost Controller- 75
Enkei Mitsubishi 17's powdercoated black with Continental tires probably around 1500miles on it.-(perfect for winters/ playing around on the dirt/ gravel roads) 450
**for some reason the PC has flaked slightly on the fronts, but it's not a big deal**
TSX retrofitted low beam projectors 4300k 35w Hids (look amazing at night!!)- 125
2g automatic awd trans- make offer
2g auto rear w/ axles- make offer
2g auto t-case- 100
2g awd front axles- 85
2g eprom ecu- 175
2g boomslang safc2 harness adapter, but I cut the wires to the afc out not knowing what this was. This would make a GREAT way to wire up your afc, accesories, anything without cutting into your unmolested stock ecu harness. We all know what a pain it is having a hacked up ecu harness, so hack this thing up and save your ecu harness!!!- 60 (these go for 140, but obviously it isn't a plug and play anymore)
Greddy Electronic 60mm boost gauge-100
Greddy electronic 60mm EGT gauge w/ probe- 125
--will sell both and throw in full a-pillar pod for 200!!!--STEAL!!!!!
Built longBlock:
-6- bolt
-Bored .20 over
-Manley H-Beam Rods
-New oem oil pump
-New alternator
-New oem tensioner
-ARP Mains
-Complete valve job
-ARP headstuds
-1800
2g auto t-case- 100
2g eprom ecu- 175
Re: Turbo/ DSM parts FS
-BAER Pro Big Brake Kit – 4 piston calipers with 13.5” rotors (cross drilled)- 500
-Rays Engineering Gram Lights 57c rims painted black w/ dunlop tires- 700
-Blitz SBC-ID boost controller- 200
-Blitz Power Meter ID- 100
250--STEAL!!!!!!!
-Front ebay and rear RRE strut tower bars- 65
-autometer a/f ultralite gauge- 15
18" ADR Kasai's in Black (two have curb rash and some paint fade) Practically new tires--perfect for winter!!!! -275
2g fwd Thermal 3" catback exhaust-300
Apexi GT-Spec Stainless Steel 3” downpipe- 75
brand new car alarm system in box- 35
aftermarket exhaust silencer( don't know what it fits)- 15
2g mas- 25
2g coil pack- 25
misc sensors
2g awd 2 piston brakes- 40 /pair
2g talon tails- 25
1g head w/ cams, condition unknown came off non-running car 75
1g head ported slightly and supposedly recently rebuilt (snapped timing belt--bent valves)- 40
2g rad (has a cracked off piece around the top fill tube, but still is good to use) -20
doors with glass and power locks and windows--driver side has broken handle- 40 each or 65 for pair
2gb talon rear bumper- 30
2gb talon wing- 40
2gb black housing headlights in good condition- 50
non-eprom 2g turbo ecus- 40
hatch with glass- 45
6 bolt awd flywheel
sunroof- 40
airbags- 35
motor mounts- make offer
rear calipers- 35/ pair
clarion cd deck- 40
2g turbo engine harness- 70
2g hatch struts good condition-25
2g fwd turbo axles OEM in great condition, 85k miles-75 for pair
2g fenders perfect condition-35 each side
misc anything, shoot request
2g mas w/ harness-30
Prices are NOT shipped
250--STEAL!!!!!!!
2g mas- 25
2g coil pack- 25
misc sensors
2g talon tails- 25
2gb talon wing- 40
6 bolt awd flywheel
sunroof- 40
airbags- 35
clarion cd deck- 40
Would like to get the headlights from you asap. call or text me whenever you get a chance, i dont get on here much. 7576347932.
I am interested, I wish I could PM you, not enough posts yet xD Do you know If I can use this on my 93 gsx if my dsm link is for a 2g maf? or do I need a harness for the maf too? thanks!
I am very interested in the 6 bolt longblock, Pm me with some contact info!
