Single Cam Build and Turbo parts block tranny too
***NEED TO SELL ALOTA SHIT THIS WEEKEND*** SHOOT SOME OFFERS
Gregg WILLING TO PART OUT NOW ----
2400 engine/parts minus "turbo kit"--3200 Everything.
757 469 1522 VA beach Ive listed the MSRP next to the new stuff but everythings OBO
Wi know im forgeting a few things but everything for it to run is here... Its about $4100 in parts and machining alone not including the engine n tranny for 3200...
This is a link to an almost identical set up making 463 HP and 352 ft/lbs
http://www.turbod16.com/viewtopic.ph...0&sk=t&sd=attp
Eagle H-Beam rods*Rated to 900hp $419
CP 8:1 comp pistons and rings* $592
OEM rod bearings* $30
Cometic Head Gasket* $87
Supertech blockguard* $97
Timing Belt* $25
DSM 440 CC injectors* $240
OBX Aluminum Trumpeted Intake manifold* and gaskets* $150
ACT HC5-XTSS street/race clutch 2500 mi on clutch $429
ACT Prolite Xact 8.8 lbs flywheel 2500 mi $366
Garrett t3 super 60 Trim (60 hot, 48 or 52 cold) *895*
2 black EM1 SI rims
Distributor with new ignition coil 130 obo
Timing Belt* $25
2 black EM1 SI rims
CPL Us Army
Re: Single Cam Build and Turbo parts block tranny too
The trans is a y8 trans? When you say rebuilt what do you mean?
easter bump
rebuilt is all new synchro's new 3rd and 5th gr. then obviously all cleaned up and made pretty lol
CPL Us Army
Sounds good, i was curious i've seen SOHC turbo guys 'rebuild' the trans with a 'custom' gearing setup for certain applications thats why i asked.
no kept all the stock Y8 gears didnt feel like mix n matchin
