Part Outs READ THIS ANNOUNCEMENT BEFORE POSTING OR RISK HAVING YOUR THREAD DELETED!
Parting out 97 gst
Old Aug 16, 2010 | 10:09 PM
Twenty5psi's Avatar
Twenty5psi Twenty5psi Twenty5psi Twenty5psi Twenty5psi Twenty5psi Twenty5psi Twenty5psi Twenty5psi Twenty5psi Twenty5psi
Default Parting out 97 gst
I am parting a 97 GST.
Rolling shell w/ 100k miles on it. The car has an authentic Rudora bodykit and is painted Lexus 2004 Lexus "Crystal White". The kit and paint cost more than 3k alone. There is absolutely no rust on the shell and was never in an accident. The rolling shell will not come with motor/ trans. It will include:
18" ADR Kasai's in Black (two have curb rash and some paint fade)
Practically new tires
Thermal 3" exhaust
Apexi GT-Spec Stainless Steel 3” downpipe
VERY sought after black interior minus the seats
Get out of that rust bucket and swap your motor/ trans into a very clean lower mileage shell!!
(pictures are from previous owner, but it looks exactly the same minus the lowering springs--will come with stock suspension)
-2000
Rebuilt engine with ARP head studs and rod bolts. (About 10k miles on motor)- 900
TRE Racing Transmission with Double Synchro 2nd, 3rd, and 4th gear. Steel shift forks. 5th Gear from an AWD transmission (gives it a longer 5th gear, so it cruises at lower RPM and has top speed of 187mph).
Quaife Limited Slip Differential- (Current price new =$1200)(only about 7k miles on everything) over 3500 in retail- 1700
ACT 2600lb clutch- 200
Fidanza lightened flywheel- 125
Buscher 20G Turbo (ported and clipped) w/ feed and drain lines/ coolant lines-750
brand new set of halo angel eye headlights- 90
magnecore plug wires- 30
Ported exhaust manifold-45
stock 2g exhaust mani-35
Ported o2 housing with Tial 40mm external wastegate w/ dumptube-225
660cc injectors-140
Walbro 255 fuel pump-40
2.5" Intake pipe w/ GM MAF and MAFT- 200
Injen Intake pipe w/ mas and injen filter- 75
17's w/ good tires, one practically new- 400
slim fan-30
99 white face gauge cluster w/ 89k miles on odometer- 75
autometer boost gauge- 30
autometer a/f - 20
eprom ecu socketed- 175
98 23 spline t-case with only 29k miles- 100
97 t-case- 75
black uncracked valve cover- 40
stock infinty cd player full din- 25
brand new car alarm system in box- 50
2g mas- 25
2g coil pack- 25
misc sensors
stock clutch w/ 29k miles- 30
extremepsi 2.5" 90* elbow w/ 1 t-bolt clamp-20
2g awd 2 piston brakes- 55
a-pillar 3 gauge pod- 20
2g talon tails- 25
1g head w/ cams- 100
2g rad (has a cracked off piece around the top fill tube, but still is good to use) -20
doors with glass and power locks and windows--driver side has broken handle- 40 each or 65 for pair
2gb talon front bumper, rear bumper, and wing- 200
2gb black housing headlights in good condition- 55
non-eprom 97 turbo ecu- 50
hatch with glass- 45
sunroof- 40
airbags- 35
motor mounts- make offer
black 2g hood with some dings-30
Alpine CDA-9884 CD & MP3 Receivers W/ pioneer rear 6x9's- 125
Pics of anything upon request. Prices do NOT include shipping.
