Go Back  VADriven.com Forums > Classifieds > Parts > Part Outs
Parting Out 700+whp Civic, Sleeved engines, Turbo kit, DSS 5.9s, s300, QUALITY PARTS! >
Part Outs READ THIS ANNOUNCEMENT BEFORE POSTING OR RISK HAVING YOUR THREAD DELETED!
Old 11-23-2013, 02:07 PM
yzracer323 has disabled reputation
Default Parting Out 700+whp Civic, Sleeved engines, Turbo kit, DSS 5.9s, s300, QUALITY PARTS!
Means of contact: PM or [email protected]
Price: $varies
Shipping is available(Buyer pays shipping and Paypal fees.)
Engine
Shortblock: benson sleeved 83mm b18c1, pauter rods, CP pistons $2500
Steel oil pan with -10 bung welded for turbo oil return
*Low miles, under 2000miles, 2 dyno sessions, 5 passes at the track
*Ran Perfectly when last used in July, Removed engine and took head off to to be built, intended to use this as a spare
Victor X intake manifold for GSR, Black wrinke finish $210
Throttle body with 3" Vanjen clamp, spare clamp to attach to your charge pipes $130
Catch can, Aeroquip lines, valve cover w/ bungs welded $300
*slightly different than pictured, same can, different valve cover and 2 lines run from the front of valve cover, 2 to rear of block.
Spare evans tuning stage 3 longblock, rated for 1000hp $4500
*Low miles, less than 1000miles, 2 dyno sessions, never tracked
B18c Block
GSR head, Stock port
83mm AEBS sleeves, Oring’d
CP pistons with HD Wrist Pins /Manley Rods
Comp stage 3 cams *good idle, drives well
Ferrea valves, springs/retainter
Oem 83mm headgasket, ARP head studs
ATI damper
-10an block fittings for catch can
-6an block fitting for water cooled turbos
Bore and Hone
Blueprint and Assembly
ACL Race Bearings
New water pump and oil pump, timing belt tensioner
Moroso oil pan, new gasket
Hasport aluminum mounts EG/DC, black poly inserts $220
Mishimoto radiator(thick core)/fan shroud/fan/-16an hoses $350
Turbo Kit
synapse motorsports T4 divided top mount w/ 2 MVS wastegate flanges, Vband downpipe, dump tubes $650
Custom 3” Stainless Vband race Exhaust, TIG welded, Vibrant Race muffler, Has a turndown under the car $150
TiAL MVS 38mm wastegates, Black $220/Ea
Forced Performance hta3586 billet wheel 62mm turbo, Ball-Bearing, T4 divided 1.06 ar housing $1200
TiAL Q blow off valve $210
Custom Intercooler, 12x24x4 core/ 3” Charge pipes, mounting brackets for EG $460
Fuel
id 2000s, run with e85, flushed with pump gas regularly. Includes clips with pigtails. $780
Edlebrock Pro Fuel rail $85
AEM FPR $80
bosch 044 fuel pumps $140/ea
Aeromotive fuel filters, 100 micron stainless element $75/ea
Fuelab 6 micron filter(e85 compatible), black anodized, w/ spare new filter element $80
Billet Fuel filter mount$20
Drivetrain
LS trans $375
LS/b16 quaife LSD $450
BWR Trans cuff, Used perfect condition $120
BWR Trans cuff, NEW $180
DSS 5.9 axles w/ hubs installed in gsr spindles, new wheel bearings $1350
Exedy twin disc, great condition $825
Electronics
Hondata 4bar MAP $80
Spare NEW boost solenoids $40
AEM Wideband gauge(black) with UEGO sensor $125
Misc.
Alt $50/ea
Half shafts $60/ea
Stock Axles $50/ea
Rear t-bracket, B-series EG/DC $25/ea
Stock integra mounts $50
NEW Stainless steel cluch line kit $55
NEW Brake tuck fitting kit $120
NEW Pushlock vacuum fitting kit $40
Autometer Boost and Oil press $50/ea
-3” stainless exhaust, magnaflow muffler $275
Nardi Steering wheel, perfect $250
NRG Short hub for EG,DC/Quick release $140
Selling everything to fund another project.
yzracer323 is offline
Old 11-23-2013, 02:17 PM
Go cry to momma
Nunyabidness's Avatar
Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness
Default Re: Parting Out 700+whp Civic, Sleeved engines, Turbo kit, DSS 5.9s, s300, QUALITY PA
Posting wheels, you still need pics of all wheels, the diameter, width, offset and lug pattern. Either provide it here or remove the info and post them separately.
Nunyabidness is offline
Old 11-23-2013, 02:21 PM
Updated
Old 11-25-2013, 09:45 AM
PM's Replied
Old 11-25-2013, 07:10 PM
jdmlyfe's Avatar
jdmlyfe has disabled reputation
will you do any trades?
jdmlyfe is offline
Old 11-26-2013, 06:59 AM
Not really looking for any honda parts, What did you have in mind
Old 11-26-2013, 07:51 PM
Got Vtec?
Freestyla2003's Avatar
Freestyla2003 is infamous around these partsFreestyla2003 is infamous around these partsFreestyla2003 is infamous around these partsFreestyla2003 is infamous around these partsFreestyla2003 is infamous around these partsFreestyla2003 is infamous around these partsFreestyla2003 is infamous around these partsFreestyla2003 is infamous around these partsFreestyla2003 is infamous around these partsFreestyla2003 is infamous around these partsFreestyla2003 is infamous around these parts
how wide are those wheels with the slicks?
Freestyla2003 is offline
Old 11-29-2013, 04:04 AM
Old 12-01-2013, 04:07 PM
Old 12-04-2013, 09:48 PM
skis0 has disabled reputation
How much for the shell?
skis0 is offline
Quick Reply: Parting Out 700+whp Civic, Sleeved engines, Turbo kit, DSS 5.9s, s300, QUALITY PARTS!
