Parting Out 700+whp Civic, Sleeved engines, Turbo kit, DSS 5.9s, s300, QUALITY PARTS!
Location: North Beach, MD Means of contact: PM or Email-yzracer323@aol.com Price: $varies Shipping is available(Buyer pays shipping and Paypal fees.) Engine Shortblock: benson sleeved 83mm b18c1, pauter rods, CP pistons $2500 Steel oil pan with -10 bung welded for turbo oil return *Low miles, under 2000miles, 2 dyno sessions, 5 passes at the track *Ran Perfectly when last used in July, Removed engine and took head off to to be built, intended to use this as a spare Victor X intake manifold for GSR, Black wrinke finish $210 http://i1212.photobucket.com/albums/...forsale042.jpg Throttle body with 3" Vanjen clamp, spare clamp to attach to your charge pipes $130http://i1212.photobucket.com/albums/...forsale044.jpg Catch can, Aeroquip lines, valve cover w/ bungs welded $300 *slightly different than pictured, same can, different valve cover and 2 lines run from the front of valve cover, 2 to rear of block. Spare evans tuning stage 3 longblock, rated for 1000hp $4500 *Low miles, less than 1000miles, 2 dyno sessions, never tracked B18c Block GSR head, Stock port 83mm AEBS sleeves, Oring’d CP pistons with HD Wrist Pins /Manley Rods Comp stage 3 cams *good idle, drives well Ferrea valves, springs/retainter Oem 83mm headgasket, ARP head studs ATI damper -10an block fittings for catch can -6an block fitting for water cooled turbos Bore and Hone Blueprint and Assembly ACL Race Bearings New water pump and oil pump, timing belt tensioner Moroso oil pan, new gasket Hasport aluminum mounts EG/DC, black poly inserts $220 Mishimoto radiator(thick core)/fan shroud/fan/-16an hoses $350 http://i1212.photobucket.com/albums/...forsale041.jpg Turbo Kit synapse motorsports T4 divided top mount w/ 2 MVS wastegate flanges, Vband downpipe, dump tubes $650 Custom 3” Stainless Vband race Exhaust, TIG welded, Vibrant Race muffler, Has a turndown under the car $150 TiAL MVS 38mm wastegates, Black $220/Ea http://i1212.photobucket.com/albums/...forsale039.jpg Forced Performance hta3586 billet wheel 62mm turbo, Ball-Bearing, T4 divided 1.06 ar housing $1200 TiAL Q blow off valve $210 http://i1212.photobucket.com/albums/...forsale053.jpg Custom Intercooler, 12x24x4 core/ 3” Charge pipes, mounting brackets for EG $460 Fuel id 2000s, run with e85, flushed with pump gas regularly. Includes clips with pigtails. $780 http://i1212.photobucket.com/albums/...forsale036.jpg Edlebrock Pro Fuel rail $85 AEM FPR $80 http://i1212.photobucket.com/albums/...forsale038.jpg bosch 044 fuel pumps $140/ea Aeromotive fuel filters, 100 micron stainless element $75/ea Fuelab 6 micron filter(e85 compatible), black anodized, w/ spare new filter element $80 Billet Fuel filter mount$20 http://i1212.photobucket.com/albums/...forsale048.jpg Drivetrain LS trans $375 LS/b16 quaife LSD $450 BWR Trans cuff, Used perfect condition $120 BWR Trans cuff, NEW $180 DSS 5.9 axles w/ hubs installed in gsr spindles, new wheel bearings $1350 Exedy twin disc, great condition $825 Electronics Hondata 4bar MAP $80 Spare NEW boost solenoids $40 AEM Wideband gauge(black) with UEGO sensor $125 Misc. Alt $50/ea Half shafts $60/ea Stock Axles $50/ea Rear t-bracket, B-series EG/DC $25/ea Stock integra mounts $50 NEW Stainless steel cluch line kit $55 NEW Brake tuck fitting kit $120 NEW Pushlock vacuum fitting kit $40 Autometer Boost and Oil press $50/ea http://i1212.photobucket.com/albums/...3/ifone112.jpg -3” stainless exhaust, magnaflow muffler $275 Nardi Steering wheel, perfect $250 NRG Short hub for EG,DC/Quick release $140 http://i1212.photobucket.com/albums/...3/ifone109.jpg http://i1212.photobucket.com/albums/...3/ifone014.jpg http://i1212.photobucket.com/albums/...3/ifone005.jpg http://i1212.photobucket.com/albums/...3/ifone024.jpg http://i1212.photobucket.com/albums/...3/ifone017.jpg http://i1212.photobucket.com/albums/...3/ifone040.jpg Selling everything to fund another project. |
Re: Parting Out 700+whp Civic, Sleeved engines, Turbo kit, DSS 5.9s, s300, QUALITY PA
Posting wheels, you still need pics of all wheels, the diameter, width, offset and lug pattern. Either provide it here or remove the info and post them separately.
Updated
PM's Replied
will you do any trades?
Originally Posted by jdmlyfe
(Post 8235735)
how wide are those wheels with the slicks?
How much for the shell?
