I NEED 98+ PROPORTIONING VALVE AND FRONT BRAKE LINES
Location: RICHMOND Means of contact: CALL OR TEXT (804)396-8752 Price: $CASH IN HAND Description: I NEED A PROP VALVE FROM A 98 OR LATER MODEL INTEGRA RS BECAUSE I WANT TO GET RID OF ABS OR IF YOU HAVE ABS PUMP WITH ALL LINES FOR A FAIR PRICE I WILL BUY IT SO HOLLA THANKS Pictures: ILOVEPENIS -- If this line is still here it means you probably didn't fill out the required information correctly and a mod will be locking your thread shortly. You should probably delete it. |
Re: I NEED 98+ PROPORTIONING VALVE AND FRONT BRAKE LINES
Text sent. I have the valve and can make the hardlines you need to delete abs. Or even a brake tuck..
Alan |
