!!! HONDA/MITSU/NISSAN Parts -- CHEAP !!!
B-Stags
Been going through the garage and getting all the spare parts together. Some parts will also be listed on ebay and I'll update this list with what parts are sold as quickly as possible.
Contact: Tim
Means of Contact: 540-915-9462 or 540-765-2105 OR DRIVENPERFORMANCE@GMAIL.COM
Pictures of any specific part or parts are available upon request!
UNIVERSAL PARTS
Turbonetics 38mm Deltagate Wastegate ----- $75
Universal Fuel pressure regulator (Silver) ----- $15
Universal Fuel pressure regulator (Blue, x2) ----- $15/ea
MERCURY
Side Markers (Mercury Cougar 99-01) ----- $5
MITSUBISHI/EAGLE
A/C Compressor-x2 (Eclipse/Talon 89-94) ----- $10/ea
ACT 6 Puck unsprung clutch disc (Eclipse/Talon 89-94) ----- $40
Lower ball joint (Eclipse/Talon) ----- $10
6-bolt 4G63 short block w/ accessory brackets ----- $150
Ashtray (Eclipse/Talon 89-94) ----- $5
Boost Control Solenoid-OEM (Eclipse/Talon 89-95) ----- $5
Transfer Case (89-94 Eclipse GSx/Talon AWD) ----- $75
MPI Relay (Eclipse/Talon 89-94) ----- $10
O.Z. Mesh Wheels..your choice black or gold (Eclipse/Talon 89-94) ----- $150
NISSAN
B13/B14 Thundervolt Plug Wires-10.2mm ----- $20
B13 Distributor ----- $50
Starter-Auto. Trans (Sentra 91-94) ----- $15
Starter-Manual Trans (Sentra 91-94) ----- $25
Alternator (Sentra 91-94) ----- $25
NX2000 Front Seats-Gray ----- $50
Mass Airflow Sensor-x2 (91-94 Sentra/SE-R) ----- $30/ea
Automatic Transmission (91-94 Sentra/SE-R) ----- $200
B13 M/T ECU-5ZE1MU ----- $50
K&N Panel air filter (95-99 Sentra SE-R) ----- $10
Passenger Headlight Assy (Nissan Altima) ----- $30
Intake manifold w/injectors (95-99 200sx/Sentra SE-R) ----- $30
HONDA
D15 Starter-M/T ----- $10
A/C Compressor (Civic 92-95) ----- $15
4G63 Turbo Cams-OEM w/ Cam gears (89-94) ----- $25
Integra LS Camshafts-OEM w/ Cam gears ----- $25
Underhood Fuse/Relay Box (Civic 92-95) ----- $10
Rear View Mirror (Civic/Si 96-00) ----- $5
Driver Side Air Vent w/Switches (Civic Si 96-00) ----- $5
Sun Visors (Civic/Si 96-00) ----- $10
Clutch Pedal Assembly w/switch (Civic/Si 96-00) ----- $20
Charcoal Canister (Civic/Si 96-00) ----- $10
Passenger side air vent (Civic/Si 96-00) ----- $2
Fuel Door-Red (Civic/Si 96-00) ----- $15
Driver & Passenger front kick panels (Civic/Si 96-00) ----- $10
Instrument Cluster besel (Civic/Si 96-00) ----- $10
Steering column switch cluster with clockspring (Civic/Si 96-00) ----- $25
99 Civic Si rear wing ----- $100
Fuel sending unit (Civic/Si 96-00) ----- $15
Driver side taillight-inner&outer (Civic/Si 96-00) ----- $25
Inner passenger side taillight (Civic/Si 96-00) ----- $10
Clutch master cylinder w/resevoir (Civic/Si 96-00) ----- $15
Brake and gas pedal assembly-manual trans. (Civic/Si 96-00) ----- $25
Steering column cover trim (Civic/Si 96-00) ----- $10
A-Pillar plastic trim-Dr. & Pass. (Civic/Si 96-00) ----- $15
B/C-Pillar plastic trim-Dr. & Pass. (Civic/Si 96-00) ----- $25
Door sills-dr. & pass. (Civic/Si 96-00) ----- $25
Driver-side lower dash (Civic/Si 96-00) ----- $20
Rear Dash (Civic/Si 96-00) ----- $20
Floor mat set (Civic/Si 96-00) ----- $15
Lower center console w/side plastics (Civic/Si 96-00) ----- $10
Glove box (Civic/Si 96-00) ----- $15
Rear lower panels-dr. & pass. (Civic/Si 96-00) ----- $25
Interior Carpet (Civic/Si 96-00) ----- $20
Power Sunroof-all parts for install (Civic/Si 96-00) ----- $125
Brake proprtioning valve for rear drum brakes (Civic 96-00) ----- $2
3" Honda civic mandrel-bent exhaust for turbo (96-00) ----- $75
Power Steering pummp-x2 (Civic 92-95) ----- $15/ea
Throttle Body-OEM (Civic 96-00) ----- $5
Battery Tray (Civic 92-00) ----- $2
Fan Switch (Civic 96-98) ----- $2
Honda D-series lower timing cover ----- $2
Radiator Fan Switch (Civic 96-00) ----- $2
Temperature Sender (Civic 96-00) ----- $2
A-Pillar 3-gauge pod (92-95 Civic) ----- $25
JDM D15B intake manifold w/ injectors ----- $75
JDM Passenger Headlight Assembly (92-95 Honda Prelude) ----- $175
Contact: Tim
UNIVERSAL PARTS
MERCURY
MITSUBISHI/EAGLE
NISSAN
HONDA
Re: !!! HONDA/MITSU/NISSAN Parts -- CHEAP !!!
^do you know the mileage? Can I get pics?
^new or used?
pm me an answer if you would
^new or used?
B-Stags
I Love to Hate
man i wish you were closer, i'd like to pick up a bunch of civic interior parts
B-Stags
B-Stags
bump...buyers fallin through left and right around here...
