Part Outs READ THIS ANNOUNCEMENT BEFORE POSTING OR RISK HAVING YOUR THREAD DELETED!
Everything CRX - D16a
Old Jun 15, 2014 | 01:29 PM
Xav H22EG8's Avatar
Xav H22EG8 Xav H22EG8 Xav H22EG8 Xav H22EG8 Xav H22EG8 Xav H22EG8 Xav H22EG8 Xav H22EG8 Xav H22EG8 Xav H22EG8 Xav H22EG8
Default Honda CRX,EF, some DA parts
Means of contact: pm or text if you have my number
Price: $see below
For all the little items, I will NOT drive far to sell. If you want a few tiny pieces you will HAVE to meet me here: 3308 Taylor Rd, Chesapeake, VA 23321
In picture:
CRX center tail light assemblies - ok condition 1 is cracked - $10/each
Oil cooler setup includes Setrab cooler, lines, remote oil filter assembly and in/out spin adapter - 75- this includes the new NAPA gold (wix) filters I have (3).
OBD1 dist - $35
CRX Mirrors - $5 / each
Mishimoto Radiator Hoses upper is slightly cut to shorten it some. - $15
Starter - $10 / ea
Crank pulley - $5 / ea
Autometer "analog" oil pressure gauge - $15
OBD0 dist w/ wires - $50
New OBD0 and 1 dist caps/rotors - $10 /ea
OBD1 IM has most sensors and all injectors - $15
New EF rear hub - $20
180 Stant Thermostat - $1
Mishimoto Thermostat - $10
OBD0 o2 sensor - $5
Honda Cam gear seals - $5
Main relays, used but works - $5
MSD Blaster Coil - $10
Hawk - Si rear pads - DTC-30 - $40
Hawk - Integra DA - DTC-60 - $65
DA Front calipers - $20each
Blue valve cover - $10
DA lower Ball joints new - $15/each
Honda fuel filter - $20
Tail light assemblies - $20 each
Centric Rear Brake disc - $20/pair
Hardrace front upper control arm bushings - $35
Blox rear v2 compensator arm to give higher toe adjustment - $35
1 qt - Honda MTF - $5
Clutch Cable - $15
Speedo cable - $10
Upper timing belt cover - $5
Used Oil Pump - $5
Radius Rod - $5
Small Battery box - $1
Gorilla security lug lock nuts (with key obviously) - $10
2 OBD0 Throttle bodies w/ functional TPS - $10 / ea
set of CRX doors - complete - $40 /each
Rear bumper w/ beam - $35
Front lower control arms - $15/ea
Rear lca - $15/ea
Radius rods - $10/ea
Cable 40mm transmission (1 left) - $75/each
1 Transmission with a fresh set of gears AND a 4.9FD but no diff (was supposed to be my spare) - $400
D16a head OEM unmolested - $50
D16y7 head - OEM - $50
D16a shortblock, complete with ACL bearings with high compression pistons - $350
Old Jun 15, 2014 | 07:18 PM
mgs1098's Avatar
II Always
mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098
Default Re: Everything CRX - D16a
Hit me up about the si harness and one of the new main relays. Also need an ac bracket off an A6 motor. Sanden comp if available.
Alan
Old Jun 16, 2014 | 06:20 PM
minihonda's Avatar
minihonda has disabled reputation
The long block what compression and what cam is in it. How may miles on it. Thanks
Old Jun 19, 2014 | 06:24 PM
fastasford's Avatar
Makin a few dolla$
fastasford has disabled reputation
Wat yr crx u got i need 88 engine harness
Old Jul 1, 2014 | 01:28 PM
Xav H22EG8's Avatar
updated thread
Old Jul 8, 2014 | 06:39 PM
nummnuttz99's Avatar
nummnuttz99 has disabled reputation
front bumper & beam pics please 5714288612
Old Jul 9, 2014 | 06:00 PM
outlaw122504's Avatar
outlaw122504 has disabled reputation
Interested in d16 text me 804-445-3720
Old Jul 12, 2014 | 06:52 PM
hatchblack's Avatar
B.E.T.P.
hatchblack has disabled reputation
you never hit me back up about the crx mirror
Old Jul 13, 2014 | 12:35 PM
sixcyl?'s Avatar
sixcyl? sixcyl? sixcyl? sixcyl? sixcyl? sixcyl? sixcyl? sixcyl? sixcyl? sixcyl? sixcyl?
Great prices. Will be in contact soon.
Old Jul 23, 2014 | 05:16 PM
EK FLY's Avatar
EK FLY has disabled reputation
JUST SEND YOU A MSG WITH MY NUMBER TEXT ME PLEASE IAM INTERESTED ON THE DOORS AND POSIBLE RACK AND UPPER CONTROL ARM
