Part Outs READ THIS ANNOUNCEMENT BEFORE POSTING OR RISK HAVING YOUR THREAD DELETED!
(2) 1990 Honda CRX HF's (1 clean body 1 with b16 swap and ctr cams) and ALOT more
Old 04-06-2009, 06:41 AM
Jason300zxTT's Avatar
Jason300zxTT Jason300zxTT Jason300zxTT Jason300zxTT Jason300zxTT Jason300zxTT Jason300zxTT Jason300zxTT Jason300zxTT Jason300zxTT Jason300zxTT
Default (2) 1990 Honda CRX HF's (1 clean body 1 with b16 swap and ctr cams) and ALOT more
Hey guys, Buddy of mine has asked me to sell his stuff for him as he is really busy. How ever he has alot of nice stuff he would like to sell including a bunch of Brand new in the box parts that never had a chance to get installed. So here we go.
(2) Honda CRX's both of them HF and 1990's. One is a clean white body that was bought with the thought of swapping the stock motor our for the other crx's b16 with ctr cam's. The White crx currently has the original motor and trans with minor rust in the rear qr's (typical crx) The other is a shell that is rusted and has the b16 swap with CTR cam's. Both cars are currently not running as it was started to do the swap. Both of these cars will need to be towed as they are not in running condition. You can either buy both crx's and have the swap or just the white clean crx as a daily. Would like to sell both with swap for a reasonable price.
Also have a bunch of parts that never even had the chance to get installed. Make in offer on all parts. I will not be low balled, but a fair price will be accepted.
Brand new balll joint and tie rod kit (new)
FULL-Race Traction bars (new)
Poly bushing's (new)
Walboro 255lph fuel pump (new)
RC 880cc Injectors (new)
Valve springs and retainers (new)
JK Tuning Jumper harness obd0 to obd1
P28 Socketed ECU
PR3 Socketed ECU
Wideband O2 inovate. (new)
LS B18B Block (needs to be sleeved good donor core) 100
B16 Swap with CTR Cam's obd0 with cable trans.
Aluminum radiator half size (new)
Stock have size radiator
Apexi-I VAFC2
5" Silver faced monster teach with yellow shift light
NX N20 kit with remote bottle opener 2 heaters and lines and solonoids ect (wet system) single fogger
Drive shaft shop stage 3 axles with hub's and extended studs B series (new)
SI wheels.
Clutch masters 6 puck un sprung clutch (new)
Jason300zxTT is offline
Old 04-06-2009, 08:12 AM
II Always
mgs1098's Avatar
mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098 mgs1098
Default Re: (2) 1990 Honda CRX HF's (1 clean body 1 with b16 swap and ctr cams) and ALOT more
Call or text Bro.. I am interested in the clean-ish crx HF shell and also a door trim piece off of one of them.. I need the larger trim on the bottom of the actual door, not the side skirt, but the 4" piece on the door.. Thanks,
Alan
757-319-3095
mgs1098 is offline
Old 04-09-2009, 01:52 PM
Stay Tuned.
tHe HyBr1d's Avatar
tHe HyBr1d has disabled reputation
you have a pm
tHe HyBr1d is offline
Old 04-10-2009, 08:23 AM
Lemonparty.org
CHUBBS_09's Avatar
CHUBBS_09 CHUBBS_09 CHUBBS_09 CHUBBS_09 CHUBBS_09 CHUBBS_09 CHUBBS_09 CHUBBS_09 CHUBBS_09 CHUBBS_09 CHUBBS_09
DO YOU HAVE THE COOLENT TEMP RELAY?
CHUBBS_09 is offline
Old 04-15-2009, 09:45 PM
dwelcher's Avatar
dwelcher has disabled reputation
If they are 99 00 si wheels pm me with a ballpark price
dwelcher is offline
Old 04-20-2009, 09:49 AM
SLOW SOL's Avatar
SLOW SOL has disabled reputation
Does your buddy have a phone number? Im interested in a few parts.
SLOW SOL is offline
Old 04-21-2009, 06:50 AM
SLOW SOL's Avatar
Traction Bar and Radiator will be sold if you contact me
SLOW SOL is offline
Old 04-21-2009, 10:52 AM
sleekef's Avatar
sleekef is infamous around these partssleekef is infamous around these partssleekef is infamous around these partssleekef is infamous around these partssleekef is infamous around these partssleekef is infamous around these partssleekef is infamous around these partssleekef is infamous around these partssleekef is infamous around these partssleekef is infamous around these partssleekef is infamous around these parts
interested in the PF Fender and the corner lights
send PM ASAP
Bobby
sleekef is offline
Old 04-21-2009, 01:21 PM
White car was sold today. Sold it for 600 cash. Guy put a battery in it, fresh gas, she started up and was driven.
I have a Black CRX HF with b16a swap with CTR cam's, full coil over suspension, full exhaust, no cat, has a test pipe, dc sports header, SI wheels, The body is pretty much done. But the parts are in decent to pretty good shape. The wheels are VERY clean. B16 runs very well ran a 13.4 on street tires in this crx.
Can buy the CRX the way it is, shell with b16a swap with ctr cam's and suspension and full exhaust for 1500 or in parts. Be easier to sell hole as a car so ill give you a deal. 1500 picked up/towed and will come with the SI wheels as well.
So here we go. Parts for sale.
b16a long block with CTR cam's, 1250 obo
b16 cable trans, 500.00
Short shifter, 100.00
stage 2 clutch, 100.00
si wheels, 450 cash plus your stock wheels and tires.obo
Apex-i Vafc2 150.00obo
Full Race Traction bars, reg price over 500 let go for 450
Half size radiator, 200 fuidyne
Drive Shaft shop, stage 3 axle's with hubes and studs, let go for 800obo
B18B block (needs to be sleeved) 100
CRX HF shell 500
Ground control coil overs with cust drag spring rates and shocks, 400
Silver Faced Autometer 5" tach with shift light, 150
Im sure ill have more parts to list.
Old 04-22-2009, 12:23 PM
all returned.
Quick Reply: (2) 1990 Honda CRX HF's (1 clean body 1 with b16 swap and ctr cams) and ALOT more
