startin my summer project (87 XJ) need advice, pointers, prayers etc
Old May 23, 2005 | 12:52 PM
nickyroo's Avatar
Default startin my summer project (87 XJ) need advice, pointers, prayers etc
i picked up an 87 XJ Chief over the winter for something to build over the summer. im not in a big rush or anything. im in the middle of yanking the motor out of it to pep it up some (new rings, valve job, gaskets, timing chain etc) and really just need to be pointed in the right direction for XJ rebuild tips. im not interested in buying the expensive-bad ass suspension stuff for it and i have no problem takin a sawzall to the fenders for more clearance. it's just gonna be a toy to take on the beach, pick up girls and maybe drive to work when its nice out. id like to see it sitting on 36" of tire or more, not so much for the performance aspect of it just because i want it to look pretty hulkish. im hoping to stay under a budget of $2500 and have it done by late july or early-mid august.
so enough of my gabbing.
i looked in the link section. NAXJA.org is down for some reason, so is rusty's. im gonna hit google up here in a minute, but if you all know of any good forums, DIY links, budget lift links, etc. itd be greatly appreciated. thanks
Old May 23, 2005 | 01:03 PM
bigd0915's Avatar
follow me if you can
bigd0915 is an unknown quantity at this point
Default Re: startin my summer project (87 XJ) need advice, pointers, prayers etc
clear 36 on an XJ??? gonna take a lot of suspension. it can be done.. but its hella suspension work. and you cant do a body lift since its unibody.
check into rockymountain suspension http://www.rockymountainsusp.com/jeep_XJ.htm
i could be wrong but i think your gonna need at least 6 inches of lift and maybe dickwhackers to clear 36's i know a guy that is doing it, he has the long arm kit from rustys and all the steering stuff and everything.
btw.. i think i was next to you the other day on warwick... red camaro plates reuter... nice looking car. i was in the big ass 4runner, with the ugly rims
Old May 23, 2005 | 01:07 PM
nickyroo's Avatar
yea the more i look into it the more expensive it looks like it's gonna be. but oh well im young i got time. im sure i'll start out with whatever i can get my hands on and slowly build her up. but im lookin to fit 36"s before its done
and thanks, i remember bein next to your ride. it looked like it was gettin ready to swallow me haha
i'll check out that link thanks bud
Old May 23, 2005 | 01:21 PM
nickyroo's Avatar
what yall think bout these for the rear?
http://www.bigoffroad.com/vendors/bigoffroad/index.htm
Old May 23, 2005 | 01:23 PM
dubwize's Avatar
skankin'
dubwize has much to be proud ofdubwize has much to be proud ofdubwize has much to be proud ofdubwize has much to be proud ofdubwize has much to be proud ofdubwize has much to be proud ofdubwize has much to be proud ofdubwize has much to be proud ofdubwize has much to be proud ofdubwize has much to be proud ofdubwize has much to be proud of
36s are no problem if your not afraid of the sawzall. a 4" lift and quite a bit of trimming will fit them. i know a buddy who has them with that setup right now. then again i would also be lookin at swapping axles with that kind of meat if you plan on doing any real wheeling
for reference the guys site is www.xjfanatic.com
Old May 23, 2005 | 01:36 PM
nickyroo's Avatar
sawzall? huh? what's that?
thanks for the link
Old Jun 2, 2005 | 11:01 AM
CivicBeaterXJ's Avatar
CivicBeaterXJ has disabled reputation
ok, if you want 36's here's what you gotta do, get rubicon express's 3.5" lift kit, put on a daystar 2" lift ontop of that the 2" lift is cheap, then for drivelines you could probably get away with using a 1" transfer case drop, axle shims, and a slip yolk out of a 2001 cherokee (1" longer) that should take care of your vibes, after that just chop the hell out of your fenders and you should have no problem fitting 36's, the hard part is the axle's, check your rear axle, if you had a trailer package there's a good chance your jeep came with a dana 44 if it did, thank the gods cause they are rare and a very good axle, you could just regear it and probably be good to go, the front axle you most likely have the HP dana 30 which is another good axle, 35's is about the strongest recomended for that axle, you may want to look into getting some alloy shafts for your front axle. go too quadratec.com and have them send you a catalog you can also go to jeepforum.com and jeepsunlimited.com those are 2 good forums. if you have any other questions you can IM me at scubajb19. I used to have a 91 cherokee that i worked on for 3 years, but started running out of time to work on it and things were breaking and wearing out faster than i could fix them so i just sold it a month ago. oh yeah , if you want i have an oil pan gasket and a rear main seal sitting in my garage so if you want them you can have them for like 10 bucks
Old Jun 2, 2005 | 11:20 AM
http://www.rubiconexpress.com/dynami...?folde*****185
3.5" lift... $350
http://www.go2rdsi.com/racing/jeep/x...spension5.html
2" daystar lift... $80
http://go2rdsi.com/racing/jeep/xjsto...ension64a.html
shims, slip yolk, and transfer case drop...$100
http://www.quadratec.com/cgi-bin/sgd...html&checked=Y
they got some pretty cheap rims there and dont rape you on shipping, i think i spent a lil over 200 for 5 black stealies
go2rdsi.com also has a sponsorship thing where you pay like 35 bucks and they give you a discount on everything, might be worth it to go thru them
http://go2rdsi.com/racing/jeep/xjsto...pension80.html
brake lines...$90 bucks
all that should take care of most everything you need except for tires and axles, those unfortunatly are the expensive part
Old Jun 2, 2005 | 12:02 PM
Crate's Avatar
poop
Crate Crate Crate Crate Crate Crate Crate Crate Crate Crate Crate
i'd avoid the shim and tcase drops. I only have a 3.5" (closer to 4") lift on my stock 01 cherokee and even with the 1" tcase drop all the vib's arn't gone. Unless you like replacing shit often.
Just spend the 200 bucks and get a SYE and save yourself the headache is my opinion.
I agree with the 3.5" RE lift + daystar for inexpensive and pretty good ride quality height. That plus a lot of cutting and you can squeeze 36's on there... but once you fit those 36s on there you had better get some gears or upgrade that d30 (i think thats whats on the older XJ's).
Old Jun 5, 2005 | 03:35 PM
the newer cherokee's get vibes with less lift quicker, i had a 91 with like 4" of lift and no tc drop or anything and didn't get a single vib, so i figured he should be ok with the route i said especially since he was on a tight budget, he definetly works on those axle's regearing that dana 30 and throw a d44 in the rear if he doesn't already have one
