Help!!!!! 4wd doesnt work anymore!!
Old 02-11-2010, 12:38 PM
caplt4's Avatar
caplt4 has disabled reputation
Default Re: Help!!!!! 4wd doesnt work anymore!!
Originally Posted by SweRveY
this is where i would start if it was me
1. check all diffs make sure no metal fragments are on the fill plug or drain plug.
2. Make sure fluid in diffs isnt shit anyway or if u have any at all
3. if that dont work im guessing u have auto locking hubs and just a switch if i read right...make sure the hubs are enganging at all u can tell this by lifting front end while in 4wd and turning wheels manuely. if front driveshaft spins not ur problem.
4 if it doesnt then it is
5. make sure ur shits is even hooked up for one joints could of went bad
to add to this which is a very good list, also include checking power to the switch than checking power to the solenoid or electric motor on the transfer case, making sure that the transfer case solenoid or electric motor is working properly by changing gears from 2wd to 4h and 4l
caplt4 is offline
Old 02-11-2010, 03:29 PM
UrGrlGveMeDkBrn's Avatar
UrGrlGveMeDkBrn UrGrlGveMeDkBrn UrGrlGveMeDkBrn UrGrlGveMeDkBrn UrGrlGveMeDkBrn UrGrlGveMeDkBrn UrGrlGveMeDkBrn UrGrlGveMeDkBrn UrGrlGveMeDkBrn UrGrlGveMeDkBrn UrGrlGveMeDkBrn
Follow that guys link and you actually might learn something
UrGrlGveMeDkBrn is offline
Old 02-14-2010, 06:36 PM
cobia fisher's Avatar
cobia fisher has disabled reputation
check your vacuum line, i have had that problem before
cobia fisher is offline
Old 02-16-2010, 05:10 PM
corona connessuer
CHAHONDA's Avatar
im pretty sure its the electric switching motor bolted to the transfer case. its what puts the transfer case in 4wd since you dont actually have a 4wd shifter. they are known to go bad on fords
CHAHONDA is offline
Old 02-20-2010, 03:58 PM
S-T-F-U
Brycerb's Avatar
Brycerb Brycerb
It doesen't work because it is a FORD.
Found
On
Road
Dead
Brycerb is offline
Everett654
08-30-2009 09:11 PM
Everett654
08-01-2009 01:12 AM
peakaboost
07-29-2008 09:46 PM
Quick Reply: Help!!!!! 4wd doesnt work anymore!!
