94 jeep xj electrical problem
so i was trying to fix my window problem and i think i accidentally made a contact with 2 positive cables. my rear running lights, radio, interior overhead lamps,cluster gauge lights, or power locks dont work. i tried replacing the fuse but that doesnt fix it. is there a wiring diagram for that specific area/fuse wiring?? i think a wire shorted out???
baller/dickbutt#69
Re: 94 jeep xj electrical problem
you need to find the correct fuse...that truck has a fuse box under the hood and under the dash...check ALL of them with a test light.
i checked them all with a test light. i have this tester that tests for positive and negative connection. its reading taht the ground is not present. so is there a diagram or something so i can trace the ground cable and find the problem? i cant seem to find one thanks
