2.5 inch front Lift for Ford..... need help....
I've ordered a 2.5 in front body lift for my 06 F150. I'm putting 33's on it and I want to do the install myself of the lift. Has anyone ever done this themselves and if so, is it too hard to do myself. the kit says I only need a floor jack, jack stands and some basic tools.
Thanks for the advice in advance
Re: 2.5 inch front Lift for Ford..... need help....
Depends which model you have. The daystar ones we sell at the shop require a front strut compression tool (coil spring compressor). If you have one that bolts on top of the factory front strut, its peanuts.
Well it says that no compressor tool is required, so i'm guessing it should be the easier one.
Here are the before and after... Thanks to Charles for his help on this.
