-   NOVA/DC/MD (https://www.vadriven.com/forums/nova-dc-md-16/)
-   -   Check Code 21 problem! (https://www.vadriven.com/forums/nova-dc-md-16/check-code-21-problem-56656/)
turboeg6 Jun 13, 2004 10:57 PM
I just swapped a OBD2 GSR motor into my 92 Civic DX. I just started it up the other day and keep getting Check code 21 which is VTEC Spool solenoid valve. The harness from my ecu to the strut tower area match up fine with the OBD2 harness to the VTEC solenoid. Is there something else that I'm missing??
Mach30SiR Jun 14, 2004 03:07 AM
Re: Check Code 21 problem!
Yep, the Tech Talk Forum :cool:
intialEK4 Jun 14, 2004 07:59 PM
did you splice anything? you just had to plug and play right??
turboeg6 Jun 15, 2004 10:27 AM
No splicing at all. I just did plug and play cuz 92 dx comes pre-wired for vtec.
EEK Jun 15, 2004 11:50 AM
i thought 92 dx needs to be wired for vtec, 4 wires total
HORNY4ZORNY Jun 15, 2004 12:47 PM
they do, this kid has no idea what hes talking about, obd2 wiring harnesses go all the way threw into the car to the ecu. obd 1 wiring harnesses break at the strut tower.obd2 and obd1 wiring hanesses wont hook up to each other theres no way. so he would have to be using a obd1 wiring harness on an obd2 motor or its a obd1 gsr swap. and the thing your missing is the knowledge on doing a proper swap
intialEK4 Jun 15, 2004 12:47 PM
http://tech.hybridgarage.com/
might help..
turboeg6 Jun 15, 2004 07:36 PM
Dearest dumbass,
The 96-97 civic was the only years where the OBD2A came 1 piece! Get your shit straight before talking shit!
EEK Jun 16, 2004 04:05 AM
Originally Posted by turboeg6
Dearest dumbass,
all ob2 civics are one piece wire harness, maybe you need to get your shit straight..i had a 96 with 99 wire harness
turboeg6 Jun 16, 2004 10:55 AM
I just posted here for some help. I didn't come here to debate about my lack of knowledge on motor swaps. If someone could help me out, great! If your just gonna be a dick about this...then don't post at all! I mean, isn't a forum about helping each other out?? :mad:
