2006 Minty Stanced Honda Ruckus (Must See! Needs to SELL FAST!) Quality Pics/Video
SOLD
ZERO TRADES WHAT SO EVER! DO NOT EVEN BOTHER TO ASK….
Let me just start off by saying, My time is very valuable at the moment and I will not waste it by entertaining window shoppers. Serious Inquiries ONLY! Reason for selling is because I am in a super tight money bind and a certain expense needs immediate attention. I am also un able to travel so you have to come to me… I am sorry but I am in a tough situation.
Price $3800
I will not be on here much at all so my Phone number will be best to text/Call if you need to get a hold of me.
Contact: rfasanarotv@gmail.com
With that being said, Up for your consideration is a super Clean Modified 2006 Honda Ruckus.
Bike is put away as of last month with a fresh oil change and all maintenace requirements up to date. It was my daily driver for about 5 months “due to a faulty NC license issue” and I have enjoyed every moment on it. I would ride sometimes from Fuquay North Carolina to Raleigh North Carolina, varying up to 3 times a week with out a single hiccup! That is 40 miles too and from. The bike runs flawlessly and has never given me any issues what so ever.
I purchased the Ruckus about 5-6 months from a fellow active soldier off of base in Fayetteville NC. It was already put together just as pictured by the previous owner, and lets just say it was done right. When purchased, it was freshly assembled and all parts where only 1 month or less old. So as it sits now, the build and all upgraded parts are only 6 months in age. (Like NEW!) This bike will come with a 6" and 8" stretch adaptors for the mojo mount kit.. It is currently max stretched at 12"... Also with come with some extra slow jets/mainjets and random Polini roller weights along with a Battery Tender!
I have many individuals who can vouch for me owning, building, and maintaing very clean/quality vehicles as well as being a stand up guy. I am super meticulous when it comes to materialistic items, and because of this my collection shows it.
I way around 170lbs and the Bike will do, give or take 42-45mph flat ground and a little over 50mph downhill… Uphill isn’t the greatest but you would expect that with a 49cc.
About 5,500 Miles on Motor And original Chassis
I am most Likely Forgetting some part upgrades…
The Good: Fresh Fluids, Runs Flawlessly, Turn key ready to go and requires no maintenence etc. FLORIDA TITLE CLEAR AND IN HAND! Which is semi rare and a BIG plus with these things and ups its value!!/ comes with original owners manual and purchase certificate from 2006! 100% street legal without having a drivers license in NC, around 75 miles to the gallon of gas (Around 1.2 gallon tank) I am the THIRD owner, super clean and it is not yours yet!
The Bad: Small oil leak behind stator. Maybe three little drips after sitting over night. I have had no time to fix it and the seal around $20. Has zero effect on performance and acts as your average minor oil leak. Very very few to little paint scuffs/chips on frame. Barely noticeable.
VIDEO- Non edited from my iPhone haha… #sorry if they drag along, #You get the point
WALK AROUND/START-UP http://www.youtube.com/watch?v=jgI3b...ature=youtu.be
START-UP/RIDE- https://www.youtube.com/watch?v=BMkNGadVhb4
Modifications and part upgrades are as followed with links… (6months old)
*iphone/GPS/Mobile Phone Holder!!!
*DORF Seat Frame - ($245.00) http://www.ruckhouse.com/index.php/d...ace-frame.html
*Dorby Works Gas Tank Cover- ($50.00) http://dorbyworks.ecrater.com/p/1733...white-gas-tank
*Bar End Mirror- ($19.99) http://www.ruckhouse.com/index.php/h...irror-278.html
*Adelin CNC Disc Brake Lever Set-($189.00) http://www.ruckhouse.com/index.php/h...-drum-255.html
*CNC Billet Handle Grips- ($15.99) http://www.ruckhouse.com/index.php/a...ips-black.html
*RRGS Low Down Forks- ($185.00) http://dorbyworks.ecrater.com/p/1652...uckus-low-down
*RRGS 4 Piston Caliper/Rotor Set- ($300) http://dorbyworks.ecrater.com/p/1724...blue-rrgs-ph80
NCY Titanium Front Axle Bolt/Nut ($33.00) http://www.ruckhouse.com/index.php/w...-axle-ncy.html
*DorbyWorks Titanium Rotor Bolts- ($16.00) http://dorbyworks.ecrater.com/p/1732...um-rotor-bolts
*RuckHouse Custom Front Wheel Hub- ($129.00) http://www.ruckhouse.com/index.php/p...wheel-hub.html
*RuckHouse Extended Rear Brake Cable- ($25.00) http://www.ruckhouse.com/index.php/a...cable-277.html
*Yoshimura Carbon GET Exhaust System- ($475) http://dorbyworks.ecrater.com/p/1768...et-stock-motor
*K&N Carb Breather- ($22.99) http://passwordjdm.com/KN-Carb-Breat...P2313C410.aspx
*RamAir Racing Foam Filter ($34.99) http://www.drowsports.com/ramair-rac...r-filter-4020/
*Older Model (Best with CNC ‘MC’ cutout) MOJO Fatty Motor Mount- ($325.00) http://www.ruckhouse.com/index.php/s...tor-mount.html
*Older Model RuckHouse rPRO Drag Bars- ($295.00) http://www.ruckhouse.com/index.php/c...ished-315.html
*PWJDM Axle Spool Kit- ($34.99) http://passwordjdm.com/PasswordJDM-R...P2888C480.aspx
*Keihin Slow Jet Kit- ($17.99) http://www.drowsports.com/slow-jet-k...ck-carburetor/
*Keihin Main Jet Kit- ($30.90) http://www.drowsports.com/keihin-hon...jets-6pc-1527/
*JC Racing Lightened FlyWheel- ($140.00) http://www.jcracingonline.com/Lighte...Core-JCLFC.htm
*Dr. Pulley ClutchKit- ($289.00) http://www.scooterdynasty.com/clutch...ascooters.aspx
*NCY CDI Box- ($104.99) http://www.scooterworks.com/ncy-perf...3#.Up07tpFqnAY
*NCY Battery ($60.00) COULDN’T FIND LINK
*High Tension SparkPlug Wire….
*Poloni Variator- ($84.99) http://www.drowsports.com/polini-var...kus-zoomer-50/
*Polini Racing Kevlar Drive Belt- ($37.99) http://www.drowsports.com/polini-rac...ruckus-zoomer/
*Dr. Pully Slider Rollers- ($21.99) http://www.drowsports.com/dr-pulley-...-16x13mm-5498/
*Kymco Rear Hub- ($60.00) http://www.ruckhouse.com/index.php/w...da-ruckus.html
*UnKnown 12x8 polished Rear wheel “Maybe Douglous?” ($250.00)
*Avon 140/70/12 Rear Tire
*12x4 Monkey Font Wheel (Price Unknown) Forgot Tire size
*Anodized Nuts and bolts…
*AfterMarket Seat…
NEXT MODS SCROLL DOWN LINK PAGE TO SEE PRODUCTS (all on same page) links the same
*Rearsets Passenger Pegs- ($70.00) http://www.mnnthbx.com/ruckus-hard-parts.html
*Adjustable Length KickStand- ($52.00) http://www.mnnthbx.com/ruckus-hard-parts.html
*CV4 Silicone Hose Set ($49.00) -http://www.mnnthbx.com/ruckus-hard-parts.html
*Turtle Head LED Taillight- ($82.00) http://www.mnnthbx.com/ruckus-hard-parts.html
PICTURES
Some of my Previous Vehicles
Price $3800
*AfterMarket Seat…
PICTURES
Re: 2006 Minty Stanced Honda Ruckus (Must See! Needs to SELL FAST!) Quality Pics/Vide
Dude, how long did it take you to build this thread.
The scooter looks great! Lots and lots of nice touches good luck with your sale!
Thanks ! Hate to get rid of it but you gotta do. What you gotta do...
need this gone
i wanttttttt
Dickbutt #peentip
You are the broest Honda bro I have ever seen,
Uppoo
Upppp
Still here
