2000 Ducati 748--- Many Upgrades
Contact: PM, 5403147977, rcparrish722@gmail.com
Miles: 15,xxx mi
Price: $5900 b/c i am trying to get rid of it I should be asking $8500+ and I have much more invested. Don't come at me with a trade of anything less than 8.5k
Trades: May consider
Just REDUCED! Must go! ...Beatiful Ducati 748... Call for a price...May also accept trades or trades with a little cash on vehicles such as 1998-1999 Eclipse GST or GSX, SR240, 300zx TT, Integra Type, Acura RSX Type S, and etc..
This bike has 15k miles on it even though the cluster shows 19k Ducati replaced the cluster with a used cluster at ~6k miles. The bike recently had a full service and tune up( oil change, valve adjustment, seals changed, chain adjusted, potentiometer and tps and other sensors were all reset to spec, and etc). The bike has been regularly serviced since new and I have all of the service records from all owners. The recent service also includes the installation of a Fast By Ferracci eprom chip, a high performance high flow air filters, removal of the restrictive intake grilles, and several new sensors. The bike has many extras like a new Lunati paint matching rear seat cover, rear fender delete and small carbon fiber turn signals, a carbon fiber triple tree cover, a carbon fiber look tank protector, a carbon fiber exhaust shield, carbon fiber heal kick guards, a carbon fiber swing arm cover, a carbon fiber bezel cover, a custom aluminum billet sprocket cover, a new black teflon chain slider, black frame plugs, black dzus clips, a tinted wind screen, and etc. All stock parts will be included. Also included are 2 spare performance oil filters, a new set of high flow air filters, a Pitbull rear wheel stand, and all factory books. I will be taking a loss here, but my loss is your gain.
Model: Ducati 748
Year: 2000
Category: Sport
Safety: See our safety campaign with the high safety rated bikes in this category.
Engine and transmission
Displacement: 748.00 ccm (45.64 cubic inches)
Engine type: V2
Stroke: 4
Power: 97.00 HP (70.8 kW)) @ 11000 RPM
Torque: 74.00 Nm (7.5 kgf-m or 54.6 ft.lbs) @ 9000 RPM
Bore x stroke: 88.0 x 61.5 mm (3.5 x 2.4 inches)
Fuel system: Injection
Valves per cylinder: 4
Gearbox: 6-speed
Transmission type
final drive: Chain
Physical measures
Dry weight: 196.0 kg (432.1 pounds)
Seat height: 790 mm (31.1 inches) If adjustable, lowest setting.
Wheelbase: 1,410 mm (55.5 inches)
Chassis and dimensions
Front suspension travel: 127 mm (5.0 inches)
Rear suspension travel: 130 mm (5.1 inches)
Front tyre dimensions: 120/60-ZR17
Rear tyre dimensions: 180/55->R17
Front brakes: Dual disc
Front brakes diameter: 320 mm (12.6 inches)
Rear brakes: Single disc
Rear brakes diameter: 220 mm (8.7 inches)
Speed and acceleration
Top speed: 240.0 km/h (149.1 mph)
Power/weight ratio: 0.4949 HP/kg
Other specifications
Fuel capacity: 17.00 litres (4.49 gallon
[ATTACH=CONFIG]93432[/ATTACH][ATTACH=CONFIG]93439[/ATTACH][ATTACH=CONFIG]93436[/ATTACH][ATTACH=CONFIG]93433[/ATTACH][ATTACH=CONFIG]93440[/ATTACH][ATTACH=CONFIG]93437[/ATTACH][ATTACH=CONFIG]93434[/ATTACH][ATTACH=CONFIG]93441[/ATTACH][ATTACH=CONFIG]93438[/ATTACH][ATTACH=CONFIG]93435[/ATTACH]
Please feel free to call me at 540 314 7977. Also if you would like additional pictures email me at rcparrish722@gmail.com with Ducati Pictures in the subject line. I have many more.
Miles: 15,xxx mi
Model: Ducati 748
Year: 2000
Category: Sport
Engine type: V2
Stroke: 4
Gearbox: 6-speed
Transmission type
final drive: Chain
Physical measures
Re: 2000 Ducati 748--- Many Upgrades
Thanks... I love this bike... Wish I did not have to let it go. I just don't have the time or the energy for it anymore. Hate to see it sit in the garage and collect dust after all the work I did on it.
