1969 Honda Cb450 $4800
The bike is a 1969 Honda CB450 with 3,160 miles on it and is located in Roanoke. Bike has had many upgrades, while the perfect running engine has remained stock.
The front end is modified with Cb750F forks and tubes with CB550 triple trees and new roller bearings.
The rear suspension is gas dampening adjustable with preload adjustment and raised 1.5" to lower rake and trail. A custom fork brace was made (you can't buy one of the shelf for this hybrid front end) and looks great while really making the front end for so much more confident. The bike handles great with this suspension and setup.
The headlight is a custom fiberglass bucket with built in tachometer (1974 CB550 tach used as its larger but still has same ratio). The bike has no speedometer in the pictures but uses a digital setup similar to a bicycle computer as to not be visually obtrusive.
The handle bar switches have been replaced with a smaller unit as there are no longer turn signals on the bike (legally not needed, and a commonly removed item when cleaning up the looks and making the bike lighter).
The tail light is a 1930's replica English design.
Exhaust is custom made and is full 304 stainless steel. Complete system is less then half the weight of the original but is also much louder.
Tires are matched Avon Road Riders.
The seat was hand made from a sheet metal and also is much lighter then the stock seat. Padding is around 1" and was modeled off of what these bikes used in their prime when modified to "cafe racer" duty.
Bike has electric and kick start. Paint is House of Kolor raspberry pearl (very close to original candy color but is urethane base, clear coat. Color is much more beautiful then pictures let on to.
*******the engine cases and cam covers have been polished since the pictures*******
This bike would make a great addition to your collection and displays the style that was popular back in its day. Please email to setup time to view this beauty. Bike is very rideable but not necessarily comfortable. This should be noted so that the new owner is happy with their new addition. Riding the bike an hour at a time isn't out of the question, but longer rides will make you ache, and want to get on your cruiser. Then after you see 5 cruisers just like yours or hit the curves, you'll want back on this one!
shaun 540-537-1545
pampadori@gmail.com
shaun 540-537-1545
pampadori@gmail.com
