07 HONDA 1000RR STREET & STRIP DRAG BIKE, CUSTOM PAINT, BLACKED OUT, VERY FAST!!
Old Jul 19, 2011 | 12:35 PM
1foxbody's Avatar
Stock Block Killaa
1foxbody 1foxbody 1foxbody 1foxbody 1foxbody 1foxbody 1foxbody 1foxbody 1foxbody 1foxbody 1foxbody
Wink 07 HONDA 1000RR STREET & STRIP DRAG BIKE, CUSTOM PAINT, BLACKED OUT, VERY FAST!!
Means of contact: Cell # 757-777-2457 call or text anytime.
Price: $11,500 OBO very negotiable serious inquiries only!
Miles: 12,5xx I still will ride the bike until it's sold.
Title: Clean title in hand.
Description: I'm selling my 07 Honda CBR 1000RR. It's never been laid down. 7/12 state inspection sticker. Always changed oil with repsol 10w40 synthetic oil. Maxima coolinol antifreeze so the bike runs at a good temperature. Runs very strong and starts right up. All aftermarket parts have been installed within the past year and I have a lot of receipts for most of the parts. The bike was completely stock when I bought it in August 2010.
I decided to build it since it's very uncommon to see honda bikes this way and I like being different. Every time I bring it out people compliment me on it and stare at it. It's also very fast I brought it to the track twice ever and my best time with it was a 6.0@116 1/8 and 9.6@144 1/4 with a 1.5 60ft while still foot shifting. Since then I changed the gearing, bought a wider rear tire, and changed the air/fuel in the higher rpm range. I will also include the stock rear seat, rear foot pegs, extra rear supersprox sprocket, and all the OEM parts I removed. I have the dynojet power commander disc to install on your computer with the usb wire to connect to a laptop to adjust a lot of features installed on the bike. I'm sure I'm forgetting things so feel free to ask any questions.
Mods:
1. Custom jet black paint job by Joey at stock or modified body works.
2. Powder coated jet black frame, swing arm, wheels, stator cover, engine cover, rear wheel hub, front and rear brake calibers, rear brake caliber bracket, and rear foot pegs by precision powder coating.
3. Dynojet power commander V. (Five)
4. Dynojet autotune with wideband.
5. Dynojet quick shifter push type sensor. (Full throttle clutchless upshifts)
6. Speedo healer version 4.
7. Akrapovic full titanium exhaust with carbon fiber canister and carbon fiber heat shield.
8. HRC carbon fiber intake.
9. BMC race air filters.
10. Ngk iridium spark splugs.
11. Motovation no cut frame sliders.
12. Ate super blue brake fluid.
13. HRC 1/6 throttle kit. (Stock is 1/4 turn)
14. CRG black short adjustable clutch lever.
15. CRG black short adjustable brake lever.
16. Accossato black quick release gas cap.
17. Gilles vcr black and gold rearsets with carbon fiber heal guards.
18. Pair block off plates.
19. Clear alternatives smoked integrated led tail light.
20. Clear alternatives smoked led flush mount turn signals.
21. Norfolk Bearing ceramic front and rear wheel bearings.
22. Brock's front caliber brackets and strap for front end.
23. HID kit hi/low beam 15,000k
24. Shinko hook up drag radial in rear 200/50/17
25. Shinko stealth front tire super soft compound.
26. RK 520 conversion gold x ring chain with rivet master style master link.
27. Driven steel rear sprocket 46 tooth. (42 tooth stock)
28. JT front sprocket 15 tooth. (16 tooth stock)
29. Thompsons Custom Cycles modified stock swingarm extended 10 inches over stock with fixed ends and relocated swingarm spools with lifetime warranty.
30. Soupy's rod end style adjustable lowering link.
31. Carbon domae1 carbon fiber gas tank upper, lower covers, and front chain guard.
32. Cleverwolf carbon fiber tank guard to protect against scratches.
33. Zero gravity double bubble dark smoke windscreen.
34. Galfer steel braided black coat front brake lines with gold ends.
35. Galfer steel braided black coat rear brake line custom length with gold ends.
36. OEM Honda 600RR seat cowl.
37. Honda bearings and seals installed in swingarm.
http://cgi.ebay.com/ebaymotors/ws/eB...%3AMESELX%3AIT
Pictures:
Old Jul 19, 2011 | 05:34 PM
bocamp's Avatar
bocamp has disabled reputation
Default Re: 07 HONDA 1000RR STREET & STRIP DRAG BIKE, CUSTOM PAINT, BLACKED OUT, VERY FAST!!
wow amazing bike! glws man
if you change your mind and you end up looking for trades let me know,
http://www.carolinahondas.com/honda-...ce-drop-5.html
Old Jul 19, 2011 | 06:53 PM
1foxbody's Avatar
Stock Block Killaa
Thanks okay I will do!
Old Jul 20, 2011 | 06:31 PM
86montess's Avatar
86montess 86montess 86montess 86montess 86montess 86montess 86montess 86montess 86montess 86montess 86montess
Bump for nice bike !!!!
Old Jul 20, 2011 | 07:57 PM
gearhead1988's Avatar
gearhead1988 has disabled reputation
Vary clean bike man Bump for the nice bike
Old Jul 21, 2011 | 10:13 AM
1foxbody's Avatar
Stock Block Killaa
Thank you!
Old Jul 21, 2011 | 06:48 PM
sleepy13's Avatar
sleepy13 sleepy13 sleepy13 sleepy13 sleepy13 sleepy13 sleepy13 sleepy13 sleepy13 sleepy13 sleepy13
Did the swingarm come with the bearings and you just replaced them? I just got mine in from Thompsons, dude said it would come with bearings. Negative... I went with the 8" stretch nervous that was gonna look dumb but that 10" looks fuckin nasty. If you still have yours when I get back on the road, I would like to meet up with you for a photo shoot since my scheme is opposite of yours. GLWS bro, if I didnt just dump 7g's into my RR i would scoop it up
Old Jul 21, 2011 | 09:14 PM
1foxbody's Avatar
Stock Block Killaa
I bought all new bearings and seals since I was getting mine powder coated. I think they cost around $75 if I can remember correctly. What scheme is your bike? Thank you hopefully mine sells quick.
Old Jul 22, 2011 | 04:19 AM
sleepy13's Avatar
The fairings are Matte White except for the lowers, they are black cuz i figured the white would get f'd up from the road grime and stuff. The frame, swingarm and bolt ons are blacked out tho. I didnt want to go overboard with the white
Old Jul 22, 2011 | 09:00 AM
1foxbody's Avatar
Stock Block Killaa
Lol ohh okay once you get it together post some pictures.
