High quality, VERY loud car audio system
Ricky Byers
chesapeake va
Contact me Via pm. we can go from there
car audio
$500 bones, firm.
OK I have decided to get rid of the system. I just want to spend money on other things so this can go. Its all hifonics equiptment, with a box made to the specific port and size specifications needed for the sub. The sub is a hifonics OLM2412. Its is 2400 watts rms and 4800 max. The amp is a hifonics Bxi 2006D brutus series. This is the 25th aniversery series of the amp and is all brushed finish with blue led's. The box is a typical sub box with dual ports. But specific for this sub. I can promise you this will make your ears bleed and your chest hurt. You will be heard for miiles. Not only is it loud but has excellent sound quality.
Amp specs
Super D-Class Monoblock Amplifier
RMS Power Ratings:
1 ohm: 2000 watts x 1 channel
2 ohms: 1300 watts x 1 channel
4 ohms: 650 watts x 1 channel
BXi AccuCross™ active electronic cross-over permits full adjustment of:
Bass EQ, Subsonic Filter, Low-Pass & Phase Shift features
RCA Input level control permits matching the amplifier input level (gain) to the CD/Receivers output level. Or the Balanced Input will accept BLD Line-Driver levels from 4 to 18-volts.
The Brutus BXi bass remote controls the subwoofer output signal from the drivers seat.
For multi-amp daisy chaining, the RCA line inputs transfer the pure untouched audio signal directly to the line output RCA jacks, bypassing any crossover settings
Hifonics New Illuminated Heat-Sink Design With Blue LED Light Pumps
Hifonics Blue Illuminated Logo
Maxxsonics Illuminated "M" End Panel Logo
Heavy-Duty Ultra-Fi™ MOSFETS
Highly Efficient Super D-Class Amplifier Circuitry With Oversized MOSFET Output
Fully Adjustable Accu-Cross™ Crossovers
±18dB Variable Bass Equalization @ 45Hz
180° Variable Phase Control (15 to 35Hz)
Dash-Mountable Bass Remote Control Included
Variable 24dB Subsonic Filter
Brutus Pulse Wave Modulated MOSFET EXVP (Exponential Vari-Power Supply)
Twin-Turbo Torroid Coil Design
HSMD Hifonics Surface Mount Design
Balance Line Inputs for our 18-Volt Line Drivers
RCA Line Output for Amplifier Daisy Chaining
Gold Oversized 2-Gauge Power Connectors
Dimensions: 16.50"L x 10.39"W x 2.63"H
sub specs
12" Dual 2 Ohms Olympus Series Subwoofer
Power Handling:
Peak: 4800 watts
RMS: 2400 watts
Impedance: Dual 2 ohms
Fiber-Glass Infused FEA Structured Cone
1" Hi-Excursion Surround
Die-Cast Aluminum Chrome Speaker Frame
Front-Plate & Voice-Coil Cooling
Double-Laminated Integrated Spider Tinsel-Lead Design
Push & Insert Wire Terminals
3" Multi-layer high-temp dual 4 ohm voice coil
160oz. High-energy magnet
1-year SonicElectronix.com warranty
Subwoofer Specifications
Subwoofer Size 12"
Subwoofer Design Round / Circle
Voice Coil(s) Dual (2 voice coils)
Impedance (per voice coil) 2 ohms
Peak Power Handling 4800 watts
RMS Power Handling 2400 watts
Woofer Composition Glass Carbon Fiber
Woofer Surround Rubber
chesapeake va
car audio
$500 bones, firm.
Amp specs
RMS Power Ratings:
sub specs
Power Handling:
Peak: 4800 watts
RMS: 2400 watts
Subwoofer Size 12"
