Built & Bagged b6 Audi 1.8t Quattro CCW ACCUAIR AIRLIFT K04
Old Jun 12, 2016 | 05:50 PM
canibeat55's Avatar
canibeat55 has disabled reputation
Default Built & Bagged b6 Audi 1.8t Quattro CCW ACCUAIR AIRLIFT K04
Former showcar. Complete air suspension kit from Bag Riders LLC. 03' a4 quattro for sale / trade. Featured on several websites and many awards won within the Audi & VW community. Currently 125xxx miles, 3500 miles on a completely built motor. car has always been garaged, suede custom interior. car was resprayed 2 years ago. Exterior is 9/10. Interior is 10/10.
$15.5k
They call me B Coolin - Automotive Features, Event Coverage, Stance, Builds, Apparel
motor- all from previous owner, over $7k in engine build
-forged internals
-arp hardware
-bored 2mm over
-JE 9.25:1 pistons
-20mm IE rifle drilled rods & bored cyl walls
-new OE spec bearings
-20mm wrist pins
-new windage tray
-new oil pump/pick up tube
-034 big bore headgasket
-AEB big port head with all new seals and very mild gasket matched porting
-secondary air pump delete, evap delete
-new south performance intake manifold gasket
-lapped valves and new valve stems seals
-gates racing timing belt with all new components
-billet ftg k04 turbo (21-18psi)
-vr6 maf
-stage 2 eurocustoms tune
-about 3500 miles on the motor
-ecs boost guage
-Forge motorsport diverter valve
-hallman boost controller
-aeromotive 340lph fuel pump
-Bosch 440cc "green giant" injectors
-redtop coil packs
-ATP 3" catless downpipe
CAR HAS A/C, HEAT & POWER STEERING
Bag steup- less than 1000 miles $3630
-accuair 5 gal color matched skinny tank
-Koni yellow struts
-airlift performance bags
-accuair vu4 solenoid valve manifold
-dual viair 400cc compressors
-Accuair management
-1/4in air lines
-zaetech digigauge
wheels-
3 piece CCW d11L with black ARP hardware $3140 in wheels alone
18x10f, 18x11r
D11L-3pc - CCWheel
Interior- $2200 for materials, labor and install. NO TEARS, RIPS OR CRACKS. NOT EVEN A LOOSE PIECE OF THREAD OR STITCHING
-suede diamond stitched seat center
-suede pillars
-suede headliner and sunroof cover
-suede armrest
-color matched interior accents
Exterior- $5800 in repaint and body (all glass removed, 3 stage paint process)
-color matched textured bumpers
-cupra R lip
-shaved trunk
the car has a stage 2 eurocustoms tune on the billet ftg k04 turbo, it's basically a hybrid k04 turbo with same size k04 hot side and larger 68mm cold side. The ftg had shaft play and I replaced it with a new, stock k03 while remaining on the same file and lowered the boost to stock level (12 psi). it's basically on a base tune. The motor is completely built and can safely handle over 600 awhp with bigger injectors and larger turbo. I still have the ftg k04 turbo which I planned on rebuilding but life got in the way of things. On the ftg it was making 388 / 309 tq at 22 psi. The new k03 is installed and i have receipts for everything. I can include the old turbo if you plan on getting it rebuilt. It still goes for $350-$425 in its current condition.
maintenance- all within the last 500 miles
brakes pads and brembo blank rotors
SS Braided brake lines
oil change with Rotella 5w40
axles
engine speed sensor
coolant temp sensor
cam position sensor
comfort module
alignment
new stock intercooler
Kevlar clutch disc
Stage 2 clutch
New battery
New coolant temp sensor
View My Video
OVER 30 PICTURES FOUND HERE
Old Jun 15, 2016 | 10:07 AM
Ultrabootz's Avatar
Ultrabootz has disabled reputation
Default Re: Built & Bagged b6 Audi 1.8t Quattro CCW ACCUAIR AIRLIFT K04
Awesome build.....need pics of the girl as well.
Old Jun 15, 2016 | 03:34 PM
canibeat55's Avatar
Thank you! Unfortunately I have limited pics of the girl lol
Old Jul 6, 2016 | 09:12 AM
tw3ak3d's Avatar
tw3ak3d has disabled reputation
If only my budget wasnt 11k!!!!
Old Jul 6, 2016 | 09:24 AM
canibeat55's Avatar
Pm me... We can discuss further
Old Jul 25, 2016 | 10:44 AM
canibeat55's Avatar
Bump for additional pics.
Old Jul 25, 2016 | 03:46 PM
91tegrsjg's Avatar
Black girls love me!
91tegrsjg 91tegrsjg 91tegrsjg 91tegrsjg 91tegrsjg 91tegrsjg 91tegrsjg 91tegrsjg 91tegrsjg 91tegrsjg 91tegrsjg
well post what limited pics you have of the girl. might bring more clients
savanna13
Jun 2, 2013 05:09 PM
cody141
Import - EUROPE
13
Dec 30, 2012 04:41 PM
90GTi
Import - EUROPE
19
Apr 18, 2008 03:11 PM
