FT: Combo package; 93 cx hatch built gsr, d2's, Skunk2, buddyclub/ and01 Lexus IS300
Old Sep 15, 2007 | 10:03 AM
mugencivic94's Avatar
mugencivic94 has disabled reputation
Default FT: Combo package; 93 cx hatch built gsr, d2's, Skunk2, buddyclub/ and01 Lexus IS300
Looking to trade my 93 cx hatch & my 01 IS300 for a nice G35, 350z , WRX, S2000 , 2006+ civicSI
Lets see some offers
CIVC
Year:1993
Make:Honda
Model: Civic
Trim: CX
The story to the car is, I purchased it from its original owner about 2 months ago. She had the car in durham all its life and garage kept it. Since Ive owned the car its always been garaged also. Very Clean car No DENTS AT ALL. These are the straightest panels you will ever find. Clean paint and immaculant interior as well. Full Back interior including mint floormats. Now to the mods.
Me and a couple of my close friends have Performed every Mod to the car so I can assure you no corners were cut and everything was done right.
Exterior: All mods have less than 500 miles
-Brand new BuddyClub P1 wheels
-New Kuhmo tires
-Oem Style Foglights
-No Dents or Dings No rust cleanest body ive ever seen I would rate it a 9 out of ten
Interior:
-05 Acura Type S seats Black Leather
-95 Acura GSR Gauge Cluster
-Razo Shift Knob
-Skunk 2 Short Throw with New Bushings and New bushings on Linkage
for that firm feel.
-No Name CD player that was Previously Installed
- No Cig burns rips or tears at all the interior is a 9.8 out of 10
Suspension:
-D2 Coilover Kit Purchased New as well less than 500 miles on them
-Omni Power LCA's Less than 500 miles on them as well
-Password Three point upper strut bar
-Skunk 2 rear upper strut bar (not installed)
-C pillar bar (not installed)
-GSR Front and Rear Brake Conversion
-Drilled and Slotted Rotors
-Hawk Pads
Engine Management:
-Chipped and Tuned P73 with S200 Hondata
Engine: Block.
- B18C1 Block Bored .20 over
- JE 12.5.1 Pistons
- Carillo Rods with ARP rod bolts
- Block guard
- Cometic head gasket
- Balanced and blue printed crank
- New ACL race bearings all around
- Unorthodox Light wieght Crank and Alternator Pullys
- Rage Header
- Mandrell bent one peice piping to a stealthy flat black Vibrant Muffler
2.5in all the way back
- Hasport Billet extremely Stiff mounts
- Fluidyne Radiator
- Slimline Fan
- Samco Radiator Hoses
- Moroso Oilpan
Engine: Head
-ENDYN P&P PR3 b16 Head
-3 Angle Valve Job
-Skunk2 valves/springs/retainers/valve seals
-Skunk2 Stage II cams
-Skunk2 Intake manifold port matched to the head and to the 68mm Skunk2 Throttle Body
-RC 370cc Injectors
-BDL Fuel Rail
-BDL Oil seal
-Skunk2 Cam gears
-Type R Valve Cover
-NGK blue wires
-NGK iradium plugs
-AEM Type R Cold Air Intake
-MSD Blaster coil with distributor
-Spoon Oil Cap
-Type R Throttle Cable
-Walbro 190 Fuel pump
-New Honda Oil Pump with Toda Gear
-Greddy Timing Belt
Tranny:
-GSR Y80 Tranny with Type R Diff and LSD
-Excedy 6 Puck Unsprung Race Clutch
-Fidanza light weight Flywheel
The Motor was broken with striaght 30 weight and ever since has only seen royal purple 5w 30 and also used the royal purple tranny fluid. The brakes and been flushed and have new fresh fluid and same with coolant. The car runs great but I have some bills i have to get paid so i have to get rid of some of the toys. The car has no issues other than the oil pan has a plug i guess i you wanted to hook up a line for a turbo setup (it came that way from moroso) and it leaks and little i just dont have a bigg enough alan key to fit it. and because the Greddy belt is a little tighter than factory it makes the cam gears a lil noisy. But im just picky.
The Engine bay has been resprayed a Green with gold pearl. I resprayed it before I put the swap in but the rest of the car is factory white, i planned on repainting the whole car this green but ive run into some finacial issues that i need to take care of.
Price :
$8500 as it sits
$9300 if I respray the outside Green Pearl.
Forgot to mention it has a clean title and heres some pics And its got a JDM_Kid wire tuck and a new battery
)01 Lexus !S300
Now the Third owner very clean , and great driving car Clean title Clean black and Dark blue factory leather and suede interior. Aftermarket JVC CD,DVD, Bluetooth, USB PORT indash UNIT. Window tint and other than that its stock. Well maintained at the Lexus stealership, NEw Tires , New Brakes pads and turned rotors, Car is equipt with factory HIDS and Badass amber foglights, this car has no issues would drive it to cali and back just looking to put both cars and get a Newer car so i ony have one issuance payment pics will be up later after it stops raining Car has also had timing belt and waterpump changed and is immaculant has 150k miles but looking at it and driving it you would never know have all service records and have no problem if you need to take it to get it looked at its in tip top shape
Old Sep 15, 2007 | 06:28 PM
Default Re: FT: Combo package; 93 cx hatch built gsr, d2's, Skunk2, buddyclub/ and01 Lexus IS
Old Sep 15, 2007 | 06:53 PM
kaltares's Avatar
CustomGSR
kaltares is an unknown quantity at this point
trade u my 00 gsr boosted teg 4 ur lex??
Old Sep 15, 2007 | 06:56 PM
no thanks
Old Sep 15, 2007 | 07:04 PM
Drifter4's Avatar
Drifter4 Drifter4 Drifter4 Drifter4 Drifter4 Drifter4 Drifter4 Drifter4 Drifter4 Drifter4 Drifter4
pm coming
Old Sep 16, 2007 | 03:32 AM
Old Sep 16, 2007 | 05:10 AM
gsr-turd's Avatar
h22 POWA
gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd gsr-turd
sent you a message
Old Sep 16, 2007 | 06:02 AM
Sherdog9's Avatar
Sherdog9 has disabled reputation
wait for the nissan 370z to come out.... it's gonna be at least 330-350hps
Old Sep 16, 2007 | 11:44 AM
Old Sep 17, 2007 | 03:26 AM
