1990 300ZX Twin Turbo T-Top, 24k mi engine, 123k mi body, 19PSI, built - VA Beach
Means of contact: 202/669-2029
Price: $8500
Description:
Price is FIRM - this is the lowest I will take for it. I am not accepting lower offers. It's gotta go THIS WEEK! This car is extremely fast. 10" wide rear tires, limited slip differential, and it breaks loose in 3rd gear no problem. Very fun to drive! Engine completely built, Tein coilovers all around, great sound system. See below for the list of modifications. Clean title in hand.
WHAT IT NEEDS:
1. New front tires. Matching Pirelli P Zero Nero's can be shipped from TireRack (ground is overnight since their warehouse is nearby) for $360. Local shops sell Cordovan's for $115/pc (but they won't match). Front tire size: 245/40 R18. (Rear is 275/35 R18). I can take care of this, no problem, but I will increase the price to accommodate the new tires.
2. The clutch makes a noise when engaging/the discs are slipping. It won't leave you stranded. The clutch grabs just fine. It's a noise, and you can drive it without making the noise if you let the clutch out a certain way. It's an RPS twin disc carbon/carbon clutch. 2 options: buy a cheaper 5 or 6-puck clutch for $400-600 or send to RPS and have them fix it for probably less than that. I would recommend the latter as it is not only cheaper, but the twin disc full carbon clutches are great for this amount of power. Here is the clutch: http://www.turboclutch.com/Pages/RPS%20ST%20Full.htm.
3. Doesn't need, but it could use a dyno tune. This will get the maximum amount of power, let you know exactly what you're putting down, increase fuel efficiency, and extend the life of the engine and turbos. On a previous build without head work, stock internals, and smaller turbos @ 16 PSI, it was dyno tuned and put down 460WHP. It's had a lot done since then, bigger turbos @ 19PSI. With tune it should easily be over 500.
4. Front right fender could use re-painting. Clear coat is stripped off of most of it. Doesn't look bad from a distance, and it's in the pictures, but hard to tell. It was from fuel rail work back in 2005 and fuel sprayed the fender.
Otherwise, she's good to go. Ready to test drive. The front tires are okay for around town, I just wouldn't take a long 3+ hour trip as a precaution.
For sale is a black exterior, black leather interior 300ZX twin turbo. The Z was originally non-turbo and a twin turbo motor was swapped into it in 2005. The engine was built by Import Parts Pro (http://www.importpartspro.com/) - the only thing stock about the engine is the block itself, which is bored .040" over. Virginia safety inspection good through 03/2014. Title in hand.
It's extremely painful for me to let this car go, but I'm moving to California and don't have the space to keep it while I'm there.
Features:
2 seater, leather seats
Power driver seat, windows, mirrors (brakes, steering too of course)
ABS
Cruise Control
A/C blows cold - I've never needed to recharge it
Digital climate control
Heated side view mirrors
Tinted
Great sound system... see below
Anyway... onto the mod list:
Garrett 2871-2 Turbos 19 PSI boost on 93 octane (electronic boost controller)
Nismo 740cc fuel injectors
Stillen Side Mount Intercoolers
Ashspec Zemulator
Oil cooler from coz
RPS twin-disc carbon-carbon clutch
A'Pexi blow off valves
A'Pexi AFC II
A'Pexi Avc-R
Dual POP, Dual MAS sensor
99 JDM front fascia (bumper) and tail lights
SpecialtyZ Exhaust
SpecialtyZ high flow cats
Defi BF series Imperial gauges:
-Oil pressure
-Fuel pressure
-Boost
-Water temp
UR underdrive pulley
Stainless Steel Fuel lines
Polished Intake Plenum
1 piece drive shaft
Koyo Radiator
Ashspec electric fan/shroud
Engine:
Wiseco pistons 88mm (.40 over)
Eagle rods
Crank polished and balanced
Water passages bored
ARP head and main studs
OEM hoses, pumps, and bearings
Heads with extreme port
1mm over stainless steel valves
500+ JWTcams
OEM lifters
JWT heavy duty cam springs
JWT heavy duty vtc spring
Jon Abler v2 Manifolds
Jon Abler 3" Downpipes
Misc:
Custom "under frame rail" IC piping
Zeta wing
Sound System:
Clarion VRX935VD DVD headunit
2 Dynaudio 6.5GT front components
Autotek 100Wx4 amplifier
Autotek 1200Wx1 subwoofer amplifier
Kicker 12" CompVR dual voice coil
Chris's sub box (from TwinTurbo.net forums)
4 gauge power/ground
Rims:
SSR gt3 18Rx8.5" front
SSR gt3 18Rx10" rear
Pictures:
Price: $8500
Description:
WHAT IT NEEDS:
Features:
ABS
Cruise Control
Tinted
Ashspec Zemulator
Oil cooler from coz
A'Pexi AFC II
A'Pexi Avc-R
SpecialtyZ Exhaust
-Oil pressure
-Fuel pressure
-Boost
-Water temp
1 piece drive shaft
Koyo Radiator
Engine:
Eagle rods
500+ JWTcams
OEM lifters
Misc:
Zeta wing
Sound System:
Rims:
Pictures:
Re: 1990 300ZX Twin Turbo T-Top, 24k mi engine, 123k mi body, 19PSI, built - VA Beach
Nice car! Also great price, Glws!!
This is gorgeous!
Wow if I had a spare 8 grand I'd be at your front door today. You don't see a good deal like this often.
Ditto...beautiful car and great price!
God i want this, beautiful car glws
Thanks all!
SyedUmarAhmad
09-26-2010 10:22 AM
