1992 Honda Accord *motor swap + 5spd swap* TONS OF NEW PARTS
Doing work mofo
1992 Honda Accord EX *motor swap + 5spd swap* TONS OF NEW PARTS
Ok since the car just sits and I dont have time to finish the car out, its going up for sale. Below is the list of things that has been done to it.
Located in Chesterfield
Clean and clear title
Milage : ?????? (need to go look at it)
1992 Honda Accord EX: Paid 600.00 for it.
SOLD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!
The motor,transmission, and LSD are worth atleast that.
Get it out of my driveway!!
The original motor was pulled out and swapped with a JDM F22b dohc engine (Japan prelude motor) Almost the same as a H23 but with cast iron sleeves and rods. The motor is all stock and runs like a champ - Paid 600.00 for it
The car was originally an automatic - I turned it into a 5spd. The transmission is a h23 m2s4 that shifts great, and it also has a wavetrac lsd in it. - Paid 300.00 for the tranny and 800.00 for the differential.
When I changed it to a 5spd, I used all Brand new Honda parts, clutch master cly, slave cly, ect. Also had a custom SSbraided line made for the clutch line plus AN fittings. Paid couple hundred
The ECU is a chipped P28 on neptune, tuned by Matt Shue @ Adrenaline auto. The car put down a slammin 151hp and 149fpt - Paid 450.00
The suspension is a Toyico illumina struts on hks full race springs, 3" drop. Front and rear upper control arms are SPC Camber kit. The car has had an alignment with the 16" Rox Oynx rims I had on their before the thread disappeared. Then I swapped rims out for the OEM's. - Paid 400.00 for the suspension and 500.00 for the camber kit.
Rims that are on the car now are OEM with 60% tread life, the car will come with the 4 Rox Oynx rims (you can even get the bent one that has a 150.00 tire on it. 16x7 - Paid 350.00 for the rims
The car just got a bunch of work done to it by Dan driskill at Adrenaline:
a) 2 new front rotors
b) 2 new front hub bearings
c) Passenger side front Hub
d) 2 new front calipers
e) 2 new front axles
f) 2 new rear rotors
g) front brake pads
h) rear brake pads
Paid - an extreme amount of money!!!!!
The car has just recently gotten:
1) new distruibor cap, rotor button, wires, and plugs, fuel filter, and a 255lph walhboro fuel pump.
2) New Map sensor
3) The cataticly converter was removed from the car and a piece of pipe was welded on. Quick fix on a bad cat and leaking exhaust. Plus a new Turbo muffler was installed because the old one fell off.
4) New heater control assembly because the old one wasnt working.
5) New windshield
6) New Radiator
When I got the car I had to replace the Window motors and regulators on all 3 windows. So they all work now.
A new stereo deck cd/player/xm sat was just installed bought from best buy - paid 180.00
There is some more things that have been done to the car that dont come to mind right off hand. I will add them as I go back over the car and look.
The car tried being stolen during the process of the swap (mexicans trying to take the motor and tranny) they bashed up the front end, so I had to replace the Hood (which was used) and i got aftermarket front bumper and fenders which fit great. But the thieves got away with nothing but a beat down and jail time. - Paid couple of hundred for the body parts.
__________________________________________________ _________________________________
The BAD:
Body has a few dents, and needs a paint job. The dents are in the doors and it would be cheaper to get the doors from a junk yard and get a paint job.
The exhaust needs to be fixed the correct way with a Cat.
Needs a gear shift boot.
Interior needs detailing.
I have over 5k invested in this car, and I realized I will not get that much back, or even close. So right now, I am boggled as to what to ask for the whole set. So I will just throw a number out there and take the best offer.
Or trades are open to anything of value to 4000.00.
g) front brake pads
h) rear brake pads
2) New Map sensor
5) New windshield
6) New Radiator
The BAD:
