1992 Acura Integra LOTS OF NEW PARTS!!!
Means of contact: Email/Text
Price: $ 3000 OBO!! Trade for Honda/Acura ONLY!
Description: I have a 1992 Acura Integra 1.8L DOHC it an automatic has a swap engine with about 100,xxx on it and 218,xxx on the body its an old car everythings not gonna be in perfect condition it has a few things that need to be adjusted and worked on such as the belt or pulley tension it squeals a little but no biggie, also the window on the driver side lacks about 1 inch from going up all the way needs a window lift havent been able to find one also may need front wheel bearings car shakes a little because of it , but u can get them on ebay cheap, but the majority of the things have been done, nothing real major or a problem it runs great its my daily driver i have no problems out of this car here are a list of the things done that are NEW!
*Battery
*Cold Air Intake
*Valve Cover Gasket
*Thermostat with all gaskets replaced
*Alternator
*Driver side CV Axle
*Power Steering Pressure Line
*Fuel Pump
*Fuel Filter
*Throttle Position Sensor
*Idle Air Control Valve
*MAP Sensor
*White Face guages that glow blue or green
*Kenwood stereo with all new speakers
*NGK Spark Plugs
*Duralast Wires
*All New Belts
*4 New Tires 215/45/17
*New Bumper Lens
*New Headlight Bulbs, And Bumper Bulbs
*Inner & Outer Tie Rod Ends Both Sides
*Sway Bar Link Kit both sides
*Lower Ball Joints both sides
*Oil Pan Gasket (changing soon) just havent got around to it yet
*Oil Cap
*Power Steering Fluid Cap
*PCV Valve
I'm sure there are other things just cant think of everything, car is well taken care of all maintenance kept up and whenever a problem comes its fixed as soon as i find out, other than that its a great car any questions text 540-968-three one one two dont have service enough to answer phone calls unless i'm at work or leave a voicemail, also open to any trades Hondas and acuras only!! no 4x4 trucks, SUV or big vehicle, worst i can say is no.....$3000 OBO alot of money & time invested into this car so no low ballers hit me up
Pictures:
*Battery
*Cold Air Intake
*Valve Cover Gasket
*Alternator
*Fuel Pump
*Fuel Filter
*MAP Sensor
*NGK Spark Plugs
*Duralast Wires
*All New Belts
*New Bumper Lens
*Oil Cap
*PCV Valve
Pictures:
WEEEEEEEEEEE
Re: 1992 Acura Integra LOTS OF NEW PARTS!!!
All of your OTHER threads for this car are closed. You only need ONE thread.
SortaFlush
Engine / Exhaust / Drivetrain
45
02-16-2012 12:44 PM
