WTT: turbo, injectors, fuel pump, safc, wastegate
Means of contact: 540-840-6882
Price: 1 million
Description: hey guys i have some stuff i want to trade for different part, i am looking for a jg victor x intake mani for b16/type r. i need cam gears, 255 and o44 fuel pump, throttle boddie pref 70mm, high impedence injectors, 44 mm wastegate, dual core radiator, 3.9 dss axles ...... im sure there is other stuff ill get the pics later tonight when i get home thanks for looking
i have a 70 trim precision turbo its a t-4 and its used came off car 2 years ago and worked fine made 488whp on 19psi ls vtec
also have an aeromotive 1000 pump
tial 38mm wg
sohc swap runs great needs new dizzy
brand new rc1000 injectors with clips
used precision 880 cc injectors
gsr cams
type r intake manifold
Pictures:ill have them tonight
ILOVEPENIS -- If this line is still here it means you probably didn't fill out the required information correctly and a mod will be locking your thread shortly. You should probably delete it.
Price: 1 million
tial 38mm wg
gsr cams
barnie3
Engine / Exhaust / Drivetrain
35
01-15-2011 06:35 AM
ikiyu
12
08-11-2009 11:57 AM
