Rotary Big Turbo parts, stock and aftermarket RX-7 stuff and a standalone ECU
Means of contact: Call/Text 571-282-9537
Price: $varies
I bought another FC thats fast already so I'm clearing out some of the build parts I've stacked up and a few other random things.
My Zip Code is 22025 in Northern VA
Contact: PM, Call/Text 571-282-9537
Prices DO NOT include shipping unless stated! If you're local LMK and I'll give you a local price.
Fuel Cut Defender for S4 $46 Shipped
Old school HKS BOV adapter tube. $100 shipped(even has 80's HKS silicone couplings)
S5 TII UIM and modded TB(secondary plates removed) $80
Rising RPM TB inlet pipe $90 Shipped
N/A trans reverse switch from an '03 Miata trans will work in an N/A FC trans. $14 shipped
S5 N/A trans with Miata gears installed from an '03. ONLY 22k original miles on the gear set. 11k on it when I bought the trans and I ran it for 11k in my car. The trans was put together by RP Performance. $800
READY TO COME OUT
6 year old S5 electronic OMP with lines, have receipt to prove it. $650
BRAND NEW MICROTECH LT-10S w/ x4 box, manual, and flying lead harness. Base tune for an S5TII
$1060 SHIPPED
CALL/TEXT 571-282-9537 or PM for offers, pics and info.
Here is the rest:
Greddy Profec Boost controller. Harness was cut but everything is there, Faceplate is loose but electrical tape or glue will fix that.
$95 Shipped
TiAL 46mm Wastegate, green spring inside, what you see is what you get
$280 shipped
BW S363 .88 turbine housing with Manifold. 90 degree compressor housing. Less than 4k on it. Oil feed and Drain lines, and V-band with section of downpipe. Car it was on made 500WHP.
$720
Bosch 044 Fuel pump and install kit.
$250 Shipped
Synapse BOV With weld on adapter and Greddy Flange Adapter(installed on it).
$220 Shipped.
Autometer Narrow band A/F gauge- New
$40
Bosch High impedance fuel injectors with pigtails and aluminum adapters for RX-7 rails LOW MILES
850cc $170Shipped
Price: $varies
READY TO COME OUT
$1060 SHIPPED
Here is the rest:
$95 Shipped
$280 shipped
$720
$250 Shipped
$220 Shipped.
$40
850cc $170Shipped
I_R_5m4r7
Engine / Exhaust / Drivetrain
03-22-2011 04:40 PM
