Oil pickup tube.
Boost is Better
Oil pickup tube.
I need an oil pickup for a b18a block. They might all be the same but I am not sure. I need one asap.
Thought my oil pump was bad but turns out there was all kinds of crap in the pickup.
Representin TeamDOHC
Re: Oil pickup tube.
they are not all the same, the ls is way different then b16 and gsr.. all i have is a gsr pic up, the only way to use that is by using the matching pan as well...best of luck to you, just wanted to clarify that so you wouldn't pick up wrong parts..
Boost is Better
oh ok thanks well then I need an LS one then. I already have my LS pan tapped for the turbo so I don't wanna switch to a gsr pan.
