NEED YOUR HELP!! WHAT IS THIS THING?
RHD EK9 CTRx
Means of Contact: 571 405 9326 OR PM
Long story short, i took my vale cover off and found this pecie i circle to be messed up. Not sure what it is call or the name. I know it hooks up to the distributor and sit on top of the cams. If you know the name or a part number or mite have one..pm a price and pic. thank you
II Always
Re: NEED YOUR HELP!! WHAT IS THIS THING?
It's a cam cap. I have a set from a GSR head. I believe they are the same. Call or text if you want it and we can work out an offer. Thanks,
Alan
757-319-3095
Alan
757-319-3095
MU-4/3 User
its a cam cradle same shit happened to me.... its a wonderful piece that cant be bought seprate.... but if u find someone parting out a motor there u go...
yah man that sucks you cant buy those seperate i broke one on a customers car had to use my spare parts or buy the whole new head best bet to find a old head and get it off that it sucks to replace too
RHD EK9 CTRx
Where the bolt that hold the vale cover. that piece is broken, i mean i can still use mine but it will be getto. It doesnt leak or anything i just want it to be perfect again.
RHD EK9 CTRx
The bolt is fine...the cap is broken where it hold the bolt. pm or text me with info and pics what head it is off of and how much shipp to 20176 va? thank
i have one but it comes with a b16 head attached. $150... the head has 152k miles on it and 1 burnt valve. you could part the head and make more money .
pm me if interested.
CIMSPORT
i would just get it welded and drill/tap, all cam caps are different for different heads, just like a main cap on a block, if you get one from another head it can have too little or too much clearance and cause wear problems and possible aluminum shavings inside the engine
