Misc. 5.0 parts from Panoz build
Fanboi
My Panoz came with a bone stock fuel injected 5.0 in it. It was an australian Ford Falcon motor so everything is the same, but the intake manifold was flipped for RHD. I had PAS install AFRs and an Ed Curtis cam along with a swap to carb etc... this is the misc. stuff I have left over. I really don't know what any of it's worth so everything is best offer + shipping
Stock fuel rails w/ injectors
Stock valve covers painted black w/ epoxy paint... nothing fancy
K&N screw in breather
Plug wire heat boots... pretty dirty
2 stock balancers
Billet EGR block-off
EFI distributor
Stock pushrods
Stock timing set
2 stock balancers
EFI distributor
Stock pushrods
Stock timing set
Fanboi
Re: Misc. 5.0 parts from Panoz build
Reman ECM
Stock MAF w/ K&N
Assortment of plug wires... there's a full set of new FRPP 9mm wires but one has a ripped up boot, the rest are perfect
EFI throttle cable
Stock MAF w/ K&N
EFI throttle cable
Carolina Kracker
i cant see photo bucket at work. on the intake, was the throttle body comming straight into the upper intake or did it have a curve to it?
